Previous in Forum: Fracture Toughness Test ASTM D5045   Next in Forum: Cutting Safe Distance From Weldments
9 comments
Geotermal
11/07/2012 4:29 PM
Hi how much is the temperature of earth in 4 feet depth
Pathfinder Tags: geotermal
Good Answers: 114
Re: geotermal
11/07/2012 4:40 PM
It depends on where you are.
Re: geotermal
11/07/2012 4:49 PM
The temperature difference is negligible for use in geothermal power generation in all but the most volcanically active areas (which are again not suitable for equipment and personnel except under the most extreme of circumstances).
You can check for yourself if you have access to a spade and thermometer.
Re: Geotermal
11/07/2012 5:12 PM
0.014285714285714285714285714285714° increase per foot of depth on adverage
I have gone to find myself if I get back before I return keep me here
Re: Geotermal
11/07/2012 7:02 PM
"the temperature of earth in 4 feet depth" is 42°F, somewhere.
Where are you?
Re: Geotermal
11/07/2012 10:45 PM
"...somewhere...Where are you?"...sir, you have a gift! :-)
Re: Geotermal
11/08/2012 7:50 AM
Re: Geotermal
11/08/2012 12:17 AM
http://www.duanesworld.net/duanesworld.net.sensors.htm
this link will help you...
Re: Geotermal
11/08/2012 3:29 AM
If it is of much difference 4ft down compared to the surface, then one is in considerable peril.
Re: Geotermal
11/12/2012 3:08 PM
I used to measure this in a job so long ago that it seems like it happened in another life. In the Northern Pa area, towards the western half the state, where the sky is cloudy 66% of the days of the year and the winter temperatures fall into the single digits, it is around 41 to 43°F. In the Austin Texas area where sunny days are vastly predominant and I doubt they ever see single digit temperatures, it is around 67°F. I barely remember W.Va. or southern Ohio, but think they were in the low fifties F.
Depends on the amount of solar heating an area gets on average and average mean temperature.
Register to Reply 9 comments
jack of all trades (1); jmmyadam (1); lyn (2); Omnib0mb3r (1); passingtongreen (1); Phys (1); PWSlack (1); TerraMan (1)
