Previous in Forum: DN80 PN40 Weld Neck Flange, DIN 2635 Type C Face   Next in Forum: Geotermal
Fracture Toughness Test ASTM D5045
11/07/2012 9:28 AM
Hello dear colleagues,
I have to perform a test for a brittle polymer and I am using the standard ASTM D5045*.
In the section 7. there is a geometrical requirement which is at the same time a validation of the reliability of the obtained results. It involves the calculation of the following quantity:
2.5*(Kq/σy) -------- it gives an idea of the size of the plastic zone
Kq is the fracture toughness calculated. σy is the yield stress. My doubt is that in my case my material does not show yielding. Should I just take the tensile strength instead?
*Standard test methods for plane-strain fracture toughness and strain energy release rate of plastic materials.
Re: Fracture Toughness Test ASTM D5045
11/07/2012 10:09 AM
11/07/2012 4:09 PM
Thank you very much lyn. However what I need is the fracture toughness and not the impact toughness (izod or charpy). Fracture toughness is given by the stress intensity factor or the energy release rate.
11/07/2012 5:04 PM
Sorry. I was never required to document fracture toughness.
What does the material supplier say?
11/08/2012 9:56 AM
Every material will yield (however slightly to strain). The real questions is whether or not the experimental apparatus at hand is physically capable of measuring the deformation. Understood that brittle materials will not exhibit much yield prior to the fracture point.
Register to Reply 4 comments
gustavoququ (1); James Stewart (1); lyn (2)
