Previous in Forum: How to Achieve Ceramic Plate Welding with Metal in an Easy and Economic Way?   Next in Forum: Fracture Toughness Test ASTM D5045
9 comments
DN80 PN40 Weld Neck Flange, DIN 2635 Type C Face
11/07/2012 12:15 AM
Dear All,
I have a problem to connect the flange to flange. For Flowmeter using Coriolis with Process Connection is DN80 PN40 weld neck flange, DIN 2635 Type C Face. Meanwhile, need Strainer which referring to ASME B16.5 Raised Face Flange Standard.
My question is :
1. What is the correct ANSI Class Flange to be connected to the flowmeter ?
Is Class 150RF / 285 psi or Class 300RF / 740 psi ?
Thank you for your answers
Regards
Wilfried
Where there is a will, there is a way. Think STRONG, Be STRONG, FINISH STRONG
Where there is a Great Power, there is a Great Responsibility. And if you want to achieve it, you must have a STRONG will. Because, where there is a STRONG will, there is a way. Therefore, you must THINK STRONG, BE STRONG, FINISH STRONG
Pathfinder Tags: ANSI PN40
Re: DN80 PN40 weld neck flange, DIN 2635 Type C Face
11/07/2012 12:39 AM
How far apart are the strainer and the flowmeter? What is the actual pressure in the system? On rough guess, PN40 ≈ Class 600. What temperature is the fluid? What else did we forget?
Good Answers: 104
Re: DN80 PN40 Weld Neck Flange, DIN 2635 Type C Face
11/07/2012 9:03 AM
Surely this is going into a piping system with a piping specification. What does the pipe spec say?
11/07/2012 8:35 PM
We are Fabricators and Engineers Company. Our customer don't tell about the specifications. They just said they are using Coriolis Flowmeter with Process Connection DN80 PN40 Weld Neck Flange, DIN 2635 Type C Flange. No other supporting information.
And they need Strainer URGENT. We have Strainer with USA Standard which is 3" ANSI 150 RF and 3" ANSI 300 RF. While Coriolis using Europe standard.
If forced to do this, whether there will be problems with the pressure?
How is the installation of the flange to flange ?
Does it require modification ?
Your answer is greatly appreciated.
Thank you
Regards
" Where there is a STRONG will, there is a way. Think STRONG, Be STRONG, FINISH STRONG "
Good Answers: 104
11/07/2012 8:54 PM
If this site, http://www.zetamec.com/ansi-300-rf-wn-std_eng.htm, is to believed, DIN 2635 is not equivalent to ANSI, although PN40 is pretty close to 300# in the 3" size.
11/07/2012 9:19 PM
So, what is the conclusion guys ?
Is the Coriolis Flowmeter DN80 PN40 can be paired with Strainer 3" ANSI 150 RF ?
Where there is a STRONG will, there is a Way. Think STRONG, Be STRONG, FINISH STRONG
11/07/2012 9:25 PM
See 1↑ for further information required.
11/07/2012 10:05 PM
It seems I can not solve this problem, because of the customer does not give me more detail about the specifications.
11/07/2012 10:57 PM
≈Most flowmeters require about 5 diameters of straight pipe upstream and 10 downstream. If so, a close-coupled strainer would be crazy.
DN80 pipe is (at least nearly) equivalent to ASME 3 inch pipe, with suitable adjustments for wall thickness. PN40 ≈ 40 bar ≈ 600 psi. This is why I mentioned Class 600. However, this also depends on temperature, which is why I asked about the actual pressure and temperature.
If the client can't furnish such information, then you have a really dumb client. In future, beware of tendering to such clients.
11/07/2012 11:47 PM
Thank you for your wise advise.
This inquiry is for tender. I think my client was afraid if our company participated in the tender. That's way he did not want to give a detailed specification of the data.
Maybe...
Register to Reply 9 comments
bigg (2); Tornado (3); Wilfried (4)
