Previous in Forum: High Pot. Test in Ungrounded Area   Next in Forum: Grading Ring
14 comments
12V Magnatron
11/10/2012 1:01 AM
as an addendum to a earlier post, how complicated is it to run a magnatron from a 12v power supply?. don't ask!
This discussion was "closed" on 11/12/2012 1:19 PM. No new comments are allowed.
Message from admins:
CR4 Does Not Support Illegal Activity.
Good Answers: 34
Re: 12v magnetron.
11/10/2012 1:18 AM
The pain is in designing the power supply.
Re: 12v magnetron.
11/10/2012 2:43 AM
i can buy a 120 v microwave and run it through an invertor, but are micrcowave ovens designed for travel traliers have a built-in invertor or do they have specially designed transformers?
Good Answers: 34
Re: 12v magnetron.
11/10/2012 3:09 AM
Of course you can run a microwave oven from an inverter. There should be no problem, provided the output is sine-wave.
Re: 12v magnetron.
11/10/2012 6:48 AM
i don't think you understood my question. please re-read
Good Answers: 34
Re: 12v magnetron.
11/10/2012 8:18 AM
You are right. I had misunderstood your question. Exactly, what are you looking for? Can you give a link to your earlier related post?
Re: 12v magnetron.
11/10/2012 10:39 AM
CR4 ADMIN: Deleted Post
Vulgar/Rude/Improper Behavior: This post was deleted because it did not adhere to the behavioral policies of the site. Please review Section 14 of the CR4 Site FAQ and the CR4 Rules of Conduct.
Re: 12v magnetron.
11/10/2012 1:31 PM
A microwave is gonna look silly on the roof of yer car!
Re: 12v magnetron.
11/10/2012 2:17 PM
Dont bother. Microwave oven magetrons work in a different frequency band than the microwave based radar guns use.
By the time the cop is close enough for your jammer to work its already too late.
Good Answers: 34
Re: 12v magnetron.
11/11/2012 12:53 AM
If you succeed in making it work, You will be a siting duck, since it will work as a transponder, giving out your position for any body to home-in. It is also illegal.
Good Answers: 104
Re: 12v magnetron.
11/10/2012 8:50 AM
Re: 12v magnatron.
11/10/2012 8:35 AM
Not that difficult if you are good with power electronics. All a magnetron needs is the proper DC input voltage of around 3000 - 5000 volts DC at a what ever wattage it rated at.
The transformers most microwave ovens use are standard iron core 50 - 60 Hz types that are not all that fussy about waveform shape within reason.
FWIW most can be taken apart and have their primary windings rewound to work at a different voltages if you can figure out their turns ratios and the proper size of wire or sets of wire to use to handle the different current demands of the new voltage.
Re: 12v magnatron.
11/10/2012 10:43 AM
would a neon light tranformer work. i think the voltage is 7500-1000v. i assume the output would be dc current.
Good Answers: 445
Re: 12V Magnatron
11/10/2012 1:29 PM
Since you have said that you are going to use it for jamming you should be aware that its use for that purpose is illegal in most jurisdictions. Don't forget that this requires knowledge of stripline fabrication techniques, plus the fact that the output of your system will blind anyone who is unfortunate enough to get in the path of the beam, screw up a pacemaker, trigger radar based door openers, burglar alarms, etc., etc.
Don't do it, the life or vision you save may be your own....
Re: 12V Magnatron
11/12/2012 4:36 AM
Most Police departments have given up on RADAR, it is hard on the officers. The common device is LASER. Somewhere in the infrared portion of the spectrum.
Never tried night vision goggles on it, and don't know if it can be discerned with a digital camera
Register to Reply 14 comments
bigg (1); durtieduck (4); Joshi (4); JWthetech (1); RAMConsult (1); tcmtech (2); TerraMan (1)
