Previous in Forum: Phase Nullify in the Electric Bus   Next in Forum: 12V Magnatron
High Pot. Test in Ungrounded Area
11/09/2012 3:00 PM
hi..all..i want to test 115 kv cable high pot test in saudi arabia..the cable is laying from one s/s to other having distance around 6 km.and cable consist of around 12 pieces. we are testing each cable individually,and joining. the problem is the location is full of sand,and we r using portable generator for power supply.my question is while conducting test is it must to ground the equipment to the ground. is there any problem if we r doing test between high voltage terminal as one point and kit earthing (without earthing)point as second point. and what will do for discharging after test. portable generator neutral need to earth? is there any problem to kit if it do like this. please help me.
Pathfinder Tags: high pot test
Re: high pot test in ungrouned area
11/09/2012 3:12 PM
Is this your first encounter with high voltage testing? If so, you might want to enlist someone with more than 3 years 6 months "testing and commissioning" experience to go on site and evaluate the conditions.
We can't see the generator, test apparatus nor any part of your set-up from here.
Have you contacted the maker of the equipment you are using?
What is your area of competence?
Good Answers: 117
Re: High Pot. Test in Ungrounded Area
11/10/2012 2:21 AM
First.. get someone who does know what they are doing, second... watch and learn!
you may think I am being harsh and unhelpful.. far from it. In 30 years I've watched cables being tested only a handful of times, but I don't even attempt it because I'm not sure what I'm doing.. never been shown.. but I know its dangerous and in the wrong hands life threatening.
Just because the area you are in is ungrounded, does not mean you can't make your own earth using VERY long earthing rods. So it goes to show you are NOT very familiar with the process, the equipment and the inherent risks.. so step back and get a professional.
Good Answers: 181
11/10/2012 1:08 PM
A/ have you got this test gear?
B/ who let you loose with it?
11/12/2012 4:02 AM
Why does the organisation not have a training programme and competence assessment regime in place?
Why does the organisation not have procedures to carry out this sort of thing?
Why is the organisation relying on anonymous responses to a global internet engineering forum to carry out its business?
Register to Reply 4 comments
brich (1); lyn (1); PWSlack (1); TonyS (1)
