Previous in Forum: Starting Current Star/Delta Starter   Next in Forum: Alternator Question
Cooling Towers
11/15/2012 12:48 AM
We are using Vsd's on our cooling Towers.I did collect data from different speeds, and I noticed that the power ratio(P1/P2) is 2.2 and the rpm ratio(RPM1/RPM2)cubed is 5. I do believe they should be close to each other.Is this an indication that the fan blade angles are too small.
Re: Cooling towers
11/15/2012 3:13 AM
What does the manual have to say on this topic?
If the fan blade pitch is too large, then several things happen. One is that the power needed goes up. Another is the risk of spray being blown over the countryside, with attendant risk of the spread of legionella pneumophila, a common risk in towers that aren't properly managed. And if the manual isn't to hand or being disregarded, proper management is at risk.
On what basis is the belief founded?
What does the tower manufacturer have to say on the topic?
Re: Cooling Towers
11/15/2012 4:16 PM
Collect the model number and serial number on the unit, and asked the manufacturer.
You have to realize that on cooling tower, you have a base unit that is based off your requirement.
And off that base your your can change motor HP (increase), Port sizing, and I imagine pitch on the blades to run over 100% of base design. (sounds odd I know)
And by running in excise of 100% this could be extra GPM, High BTU's exchange, different temperature differentials, ect......
