Previous in Forum: Ladders and Platform On Horizontal Vessels   Next in Forum: Mag Welding Question
11 comments
SS Pressure Vessel
11/15/2012 2:59 AM
Good day.
I am designing an air receiver using SS304. Do i need to add a corrosion allowance for SS vessels?
Re: SS pressure vessel
11/15/2012 3:21 AM
It depends upon the process fluid(s), its/their temperature(s) and pressure(s).
11/15/2012 3:41 AM
Most air receivers are constructed in lower-grade steels. Why 304 for this one?
11/15/2012 3:47 AM
Client requirement..
11/15/2012 3:48 AM
Based upon what?
11/15/2012 3:49 AM
ASME VIII Div 1
11/15/2012 4:21 AM
Why does this client want a 304 one instead of a carbon steel one? What is so special about this air? What is different about the piping system? - is it 304 too?
11/15/2012 7:43 AM
What was the outcome of the initial discussion with the Engineer/Surveyor from the company providing burst indemnity insurance cover on the equipment?
Re: SS Pressure Vessel
11/15/2012 9:05 AM
Joe:
- Most air receivers are of carbon steel construction and meet ASME VIII or its equivalent. Stainless is an acceptable ( but expensive) alternate.
- All air receivers collect condensate which slowly corrodes the bottom of the carbon steel receiver. This corrosion problem is most often addressed by periodic blowdown of the receiver. This can be done via a tank drain manually, on a timed valve or via a sensor for liquid level.
- I would use a 20mm corrosion allowance for a SS receiver
11/15/2012 7:17 PM
Thanks bud..... you mean 2.0 mm...
Good Answers: 137
11/16/2012 11:03 AM
20 mm does seem a little generous....
11/18/2012 3:01 AM
I'm even thinking 0.2 mm, but there may be some minimum standard thicker than that.
Register to Reply 11 comments
Anonymous Poster (1); Codemaster (1); inspectorjoe (3); PWSlack (5); Tornado (1)
