Previous in Forum: Pumping System - Vapour Pressure   Next in Forum: York Manual
14 comments
Pump Testing
11/21/2012 8:34 AM
My pump will be tested on next month.
The actual suction pressure is 1612 psig. and Differential pressure is 1903 psi.
Will manufacturer keep this suction condition?
or they just show, pump is developing 1903 psi , at any suction pressure.
That is can they keep suction pressure 20 psig, and show us see the discharge pressure is 1923 psig. hence the pump is ok...
Please help.
Re: Pump Testing
11/21/2012 8:53 AM
Provided the inlet pressure is sufficient to prevent cavitation, the fact that the differential pressure and flowrate fit the manufacturer's published performace curve is the result of a satisfactory test. Don't worry about the inlet pressure being 20psig or 1620psig, or any value in between.
That's quite some pump, and quite some pipework!
Re: Pump Testing
11/21/2012 10:10 AM
You've been flogging this same pump since at least January of this year.
I suggest that you take a course in fundamentals of pumps and save us all some aggravation.
[DOC] PUMP BASICS
Your questions suggest a complete lack of fundamental understanding of pumps!
Re: Pump Testing
11/21/2012 10:52 AM
Ooooh! Well spotted. Good recommendation.
<unsubscribes>
Good Answers: 137
Re: Pump Testing
11/22/2012 5:18 PM
As PWSlack says, as long as the suction pressure is high enough to avoid cavitation, it shouldn't make any difference. But I'd guess with ΔP like that the suction pressure needs to be much higher than 20 psig. What does the pump supplier say? If you have 1612 psig available it's not likely to be a problem, but he ought to tell you.
I would expect the supplier to prefer a high suction pressure for the test as that's more likely to avoid any cavitation risk, and improve the chance of passing the test.
Re: Pump Testing
11/22/2012 7:13 PM
Are you testing using the same operating fluid of the same density? keep in mind that pressure change with density. Better to test the head in meter of feet.
Re: Pump Testing
11/22/2012 7:50 PM
Could you explain, "Better to test the head in meter of feet."?
Good Answers: 19
Re: Pump Testing
11/22/2012 11:09 PM
Given the proximity of the "r" and "f" keys, he might have meant "meter or feet".
Or maybe he's a bad speller like I am.
Re: Pump Testing
11/23/2012 2:17 AM
Sorry typo error, it should read "meter or feet"
Re: Pump Testing
11/23/2012 2:47 AM
It's an easy enough conversion. 4389 feet of head.
Good Answers: 137
Re: Pump Testing
11/23/2012 4:17 AM
That's if it's water, less feet if SG is higher.
Re: Pump Testing
11/23/2012 9:01 AM
This is from January of 2012 thread on the same subject by OP: "The above pump will be tested with water at flow: 610.4 gpm, rated".
AS I said earlier, OP's been flogging this same pump for almost a year, with no progress that I can see.
They don't seem to have learned anything about pumps in that year, either.
Good Answers: 137
Re: Pump Testing
11/23/2012 9:28 AM
OK thanks, I'll have a read of it for amusement
Good Answers: 19
Re: Pump Testing
11/24/2012 12:06 PM
So reading between the lines, some large producer of CO2 is in dire need of a pump testing expert?
Re: Pump Testing
11/24/2012 12:17 PM
Looks like they have been in dire need of competent engineers for over a year.
Register to Reply 14 comments
Codemaster (3); lyn (5); PWSlack (2); Ried (2); sabriahmad (2)
