Previous in Forum: Works on Energy   Next in Forum: Permanent Magnetic Generator
10 comments
Clarification with Generator Neutral Earthing, Neutral Link and Neutral Out
11/24/2012 9:23 AM
The generator neutral out is earthed for attaining two targets. (1) for a getting zero potential in neutral and hence balanced voltage (2) for benefiting a return path, so that overload or earth leakage could be sensed and to protect.
The neutral link is provided because to isolate the earthing in case of testing or so.
CT for EFR is kept after NL
CT for REF is kept before NL
If the arrangement (2) is correct, I believe EFR-CT could sense the earth (leakage) current and REF-CT could sense the residual current in between neutral & earth. But, by the arrangement (2) if any loose contact with NL, voltage unbalancing may occur. So, many prefer (1), if REF is not there.
Please discuss.
Assistant Electrical Inspector, Govt. of Kerala, India
Pathfinder Tags: generator neutral earthing
Re: Clarification with generator neutral earthing, neutral link and neutral out.
11/24/2012 9:36 AM
You seem so conflicted.
The NVR is not balanced, therefore the BFD will not be in phase with the EFR nor the ABC/MCb.
The return path is not clear here, so the RTB period will be longer.
Reversing the NL with the CT will help the NFR, but the only sure cure is two aspirin and a NAP.
OT.
Good Answers: 34
Re: Clarification with Generator Neutral Earthing, Neutral Link and Neutral Out
11/24/2012 12:00 PM
CT for REF is kept before NL: What your REF stands for?
CT for EFR is kept after NL: Your EFR, does it stand for earth fault relay or emergency frequency relay?
And what is your NL stand for?
Neutral Link? Why do you need it & for what kind of testing?
Can we see a sketch of your system incorporating all these?
By the way are your seniors, members if this forum? If not, please invite them to this August forum.
11/24/2012 1:15 PM
REF - Restricted Earth Fault Relay
EFR - Earth Fault Relay
NL -Neutral Link
Testing Means - Insulation Reading Measurement - In such occasions, the earth connection may need to be disconnected.
11/24/2012 2:32 PM
Neutral isn't about getting balanced voltages, Guv. Neutral is about providing a route for the imbalance current on single-phase loads. At least, it was when I went to classes.
Good moaning!
11/24/2012 10:47 PM
If the neutral is not strongly earthed, the phase voltage which is getting in between phase and neutral will be unbalanced. This is what I meant.
Anyway, please refer to my route doubt. Which connection is advisable (1) or (2) in the diagram? If my query is not clear, I am ready to give again clarifications.
Good Answers: 170
11/25/2012 2:23 AM
To put your question precisely, you want to know whether neutral distribution should be before the REf CT or after the REf CT. Is it so?
11/25/2012 4:28 AM
Yes, there lies a point.
For REF protection to locate internal faults, we use 3 line CTs and one neutral CT. I have shown only the neutral CT with the diagram. It should sense the neutral current, which is the total of the three line currents. In a balanced condition, this neutral current must be zero. When some internal fault occur, an unbalancing will occur and the net current will cause the REF relay to trip. The neutral earthing path gives a return path for any earth faults/leakages, which causes a current ('Ie') to travel. Let actual neutral current be, In (without 'Ie'). So, total neutral current (to the generator side) will be 'It' = 'In' + 'Ie'. The REF sensing CT in the neutral path should read 'It' and not 'In'. Am I right? If so, the CT should be located to read 'It'. With connection (1) in the diagram the REF CT can not read 'It', instead only 'Ie' will be sensed. So, connection (2) is preferable. Please analyse.
Good Answers: 170
11/25/2012 9:35 AM
I am a trainer with L & T and conducting protective relay training programme is my cup of tea. I have thoroughly analysed the prepositions and have made a presentation on the same. But, being a computer novice, I am unable to post them here directly. However, if you can send me your mail ID thro this forum's mailbox, I will be able to send you the presentation by mail.
12/03/2012 9:13 AM
After an alround search, I conclude here below the clarification which I asked. Neutral out need to be from the incoming side of NL, before which REF CT is to be included. All other details remain same, as I explained earlier.The final diagram shall be as follows.I welcome, any more doubt if there.
09/09/2013 5:15 AM
Dear EE65,
I know I am visitng this thread after long time, however , I am faced with similiar situation now. In case you can share your above mentioned presentation, it would be great help to me as well.my mail id is mailtodkp at gmail do com.
Best regards
dinesh
Register to Reply 10 comments
Crabtree (1); dinesh_kp (1); electricalexpert65 (2); Joshi (1); lyn (1); user-deleted-1098 (4)
