Previous in Forum: Clarification with Generator Neutral Earthing, Neutral Link and Neutral Out   Next in Forum: Thermo-Electricity
Permanent Magnetic Generator
11/24/2012 1:49 PM
In a siemens generator excitation system there are two exciter one named pilot exciter is (permanent magnet generator)type and other is seperatley excited type, PMG Has 07 wires,05 wires for output i-e UH1 &UH2=80V AC, WH1 & WH2=80V AC, And WH1 & WH3=175V AC These 175v ac going to a rectifier bridge to convert in DC supply from here these DC VOLT are going to stator of same PM Generator by remaining 02 wires(Input wires) and 80v ac supply of this PMG is going to AVR, output of this AVR is going to excit separately excited generator, output of this separately excited generator is going ROTOR of main generator, this permanent Magnet Generator fuction getting back supply in STATOR is new for me which I want to know Why this supply is going back in stator of PMG
Re: Permanent Magnetic Generator
11/24/2012 1:53 PM
Because it can.
11/24/2012 10:44 PM
Your general explanation is difficult to understand.
A wiring diagram of the wiring migt help.
11/26/2012 2:45 AM
Long story and i didn't understand
Good Answers: 804
11/26/2012 10:48 AM
Do you understand how a synchronous machine works? It needs excitation of the rotor field in order to produce electricity. If connected to a grid, the excitation power can come from the grid itself. But if in "island mode" where there is no existing power to get it from, the power to excite the rotor field has to come from somewhere first. That somewhere is the PMG. But once the PMG is getting excitation to the rotor, the generator (alternator) can now supply it's own excitation power and be self sustaining until the next time it is shut down.
Register to Reply 4 comments
caeser (1); garth (1); JRaef (1); lyn (1)
