Previous in Forum: Freewheeling Diode Across an Inductive Coil   Next in Forum: Flowmeter Electromagnetic Siemens Mag3100
Barriers
11/25/2012 10:51 PM
There is a query by my client if Fieldbus barriers (used in the field) have the same function as IS barriers. FYI, the device type used is Exnl (residing in Zone-2) and there is a discussion about the need to go for an FF barrier in the field. In a previous project having similar configuration (Exnl & FF protocol), there were no barriers used in the field. But since it is still under commissioning stage, cannot consider it as a reference.
Any suggestions?
PS: I am an amateur in this field....
If something goes wrong at the plant, blame the guy who can't speak English
Re: Barriers
11/25/2012 10:59 PM
Have your client call me.
Good Answers: 34
Re: Barriers
11/25/2012 11:54 PM
Good Answers: 34
Re: Barriers
11/26/2012 3:58 AM
Thank you, (whoever you are) for the GA.
Re: Barriers
11/26/2012 3:28 AM
<...amateur in this field....>
Selecting, installing and using hazardous area electrical equipment cannot be done safely without some training. So stop. Either:
  1. hand the job over to someone that knows what to do, or
  2. wait until a proper training course has been tackled and completed.
  3. There is no third option.
Re: Barriers
11/26/2012 7:12 PM
PWSlack, the project has not even started and is still under discussion stage, so the question of selection, installation or usage does not come here. I have 3-4 years of experience in Fieldbus Foundation in the hardware used in cabinets and HMI but not in the field.
This query has nothing to do with me working on it since it is only for information.
Re: Barriers
11/27/2012 9:06 AM
If the project will use Foundation Fieldbus then the barriers are a must.
Also if you are using barriers you can use less expensive sealing mechanisms.
Finally if you are an amatuer, please consult professionals, since they are the only ones who will know all the applicable codes, standards and equipment to use, here we are trying to give answers where the supplied information is generally less than complete, so any and all answers have to be confirmed.
Re: Barriers
12/14/2012 11:47 AM
Will Fieldbus replace LAN type BUS connections?
Register to Reply 7 comments
cbob12 (1); Joshi (2); karthik301 (1); lyn (1); PWSlack (1); vargaalex (1)
