Previous in Forum: Barriers   Next in Forum: Calibration - Zeroing and Taring
Flowmeter Electromagnetic Siemens Mag3100
11/26/2012 1:27 AM
good morning everyone ,
kindly i need some clarifications about the earthing for the the electromagnetic flow meter type Siemens ,is it important to connect earthing cable from the both flanges side ,or connect one flange side only enough ? kindly advice .
Good Answers: 34
Re: Flowmeter Electromagnetic Siemens Mag3100
11/26/2012 1:41 AM
Your electromagnetic flow meter is made by Siemens. What is the model/type no? What does the installation instruction say about grounding? I suppose you are installing/commissioning this instrument. Have you sought support from Siemens?
Good Answers: 34
11/26/2012 2:39 AM
Please visit https://eb.automation.siemens.com/goos/catalog/Pages/ProductData.aspx?language=en&nodeid=10061921&tree=CatalogTree&regionUrl=/#topAnch&activetab=product&
and download the manual. It gives all installation instructions, including methods for required grounding. How come you do not have a manual? Or you do not understand the grounding methods described there-in? Please revert back with the results.
11/26/2012 2:58 AM
yes sure am have the manual the problem here that my manager need to fix from both side not one flange side as the manual and so i need support with field experience to help
thanks
11/26/2012 3:24 AM
OK, so read the manual and telephone the Siemens technical support line if anything is unclear.
Good Answers: 34
11/26/2012 3:36 AM
Show the manual to your Manager, or make him speak to & confirm with Siemens. Read carefully, the entire manual. Highlight the text relating to grounding.
11/29/2012 3:06 PM
Many of these Siemens mag meters do not require separate earthling as they have earthling electrodes. If you see 3 electrodes in the tube then the one 90 degrees out from the other two is the earthling electrode.
If you only have two electrodes then you need an earthling ring and it is best to put it at the inlet side of the sensor.
If flow goes both ways then use two rings.
Hope this helped.
Cheers,
Eric
Register to Reply 6 comments
Ahmadnaggar (1); Ducdude (1); Joshi (3); PWSlack (1)
