Previous in Forum: Flowmeter Electromagnetic Siemens Mag3100   Next in Forum: Cable Ladder Expansion Joint Plate Installation
Calibration - Zeroing and Taring
11/26/2012 9:02 AM
Hi, can someone give me a distinction between zeroing and taring
Re: calibration
11/26/2012 9:09 AM
Zeroing means just that. Setting the indicator at zero.
What is tare weight? definition and meaning
Re: calibration
11/27/2012 2:45 AM
In some scales there are both tare and zero buttons, what happens when one press either, and which one is advisable to use on daily operation, not in calibrating. please advice
Re: calibration
11/27/2012 3:36 AM
See #1↑.
Re: calibration
11/28/2012 12:30 PM
When You have nothing on the scale, press zero button. This allows the scale to make correction of errors (caused by temperature changes, humidity, supply voltage, dust on scale, drift of zero with time...)
When You have empty container, box,..something to contain what You really want to weight, press tare button. Scale will write displayed weight (of container) to internal memory, and will subtract this value from results of next weighting. This allows to know netto weight of this, what You will put to container, without using calculator.
Re: calibration
12/19/2012 5:22 AM
Thank you, i get the difference. so zeroing is part of calibration.
Re: calibration
05/14/2013 7:11 AM
Not calibration. Just zero-ing (if there is such a word ).
Register to Reply 6 comments
czgut (1); lyn (1); mitey (2); PWSlack (2)
