WE HAVE A FLUIDOTECH ROTARY VANE PUMP TYPE- 2511E( HIGH PRESSURE & LOW FLOW ) IN OUR HYDROGEN GAS GENERATION PLANT, DESIGN OF PLANT IS SUCH THAT WE HAVE 2 HYDROGEN GAS GENERATION UNIT IN LINE HAVING SOLENOID VALVES IN DM WATER FEEDING LINE FOR BOTH UNIT, IF LEVEL OF DM WATER IN GENERATION UNIT DECREASE THAN THESE VALVES OPEN FOR FEEDING DM WATER TO THE UNIT & IF SOLENOID VALVE OF BOTH UNIT REMAIN CLOSED THAN DM WATER FEED TO THE BREAK TANK THROUGH LOW PROPORTION RELIEF VALVE SET TO 13 BAR PRESSURE, MY PROBLEM IS THAT WHEN DM WATER FEED TO BOTH UNIT AT THE SAME TIME THAN PUMP WAS NOT ABLE TO DELIVER THE REQUIRED QUANTITY TO WATER,
