Previous in Forum: ROTARY VANE PUMP NOT DELIVER SUFFICIENT FLOW TO FEED DM WATER TO H2 GAS UNIT   Next in Forum: Bagasse Fired Boilers
17 comments
Flow Through Pipe in Accelerated Body
11/27/2012 4:00 AM
Hi,
Could you tell me how the flow rate through pipe is effected when the whole body is accelerating in the shown direction.
I understood that, the flow rate through this pipe will reduce for the available pressure difference, during the body acceleration compared to the case of acceleration is zero.
But it is mentioned that, at cross section 2 pressure will be reduced because of acceleration. what it means?
And, if i measure pressure at mid point of length, will it vary (for a constant pressure difference b/w sec. 1 & 2) for with and without body acceleration cases?
Kindly consider the system as it is shown. Lines Before & after sec. 1 & 2 are not shown for clarity of question.
Good Answers: 34
Re: Flow through pipe in accelerated body
11/27/2012 4:19 AM
I am looking at a steam engine, running at a constant speed. The boiler feed water pump is pumping water, as & when required. I see no problem any where. Just dreaming/speculating if my aunt had a mustache.... has no real world meaning....
11/27/2012 4:29 AM
"I am looking at a steam engine, running at a constant speed ... I see no problem any where."
...but the OP is particularly interested in an accelerating frame of reference.
Good Answers: 34
11/27/2012 4:33 AM
My steam engine is in that state.
11/27/2012 4:29 AM
If the device that is supplying the flow is travelling with the pipe, then there will be negligible effect unless the pipe is approaching the speed of light.
If the device supplying the flow is not travelling with the pipe, then one has a non-real-world device.
11/27/2012 4:54 AM
Assuming that you know how to do all the calculations for a given force (Fold) in a non accelerating pipe, then:
Fnew = Fold - ma
Where m is the mass of the liquid in the pipe.
Good Answers: 29
11/27/2012 8:21 AM
Indeed, you now have a situation not unlike pumping water from a low tank to a higher tank only the acceleration and resulting force is in the horizontal direction.
OP, do you need to take into account that gravity is still working on your system?
11/27/2012 5:56 AM
Sir,
I'l explain bit more.
I've two tanks in aircraft and transferring fuel from Tank 1 at higher pressure to tank 2 at atmospheric pressure. If my aircraft accelerate as shown in figure, then my flow rate will decrease for the same air pressure in tank 1.
Please, if not come across the situation, don't think that it is not possible and don't give unnecessary comments which spoils the discussion.
11/27/2012 7:37 AM
If the pipe remains connected and the planes and the pipe accelerate at the same rate, there will be no change in fluid flow.
If one of the planes accelerates at a different rate to the other, then the pipe will break, at which point there will be increased flow from the plane pumping the fuel and no flow at the plane receiving fuel, assuming both planes survive the experience. What happens in the pipe depends on where it breaks.
11/27/2012 8:11 AM
Er ... how many aircraft are involved?
Re: Flow Through Pipe in Accelerated Body
11/27/2012 8:16 AM
What does your instructor say?
Anonymous Poster #2
11/27/2012 8:23 AM
If we don't actually give him the answer to his homework, can we give him hints instead? Please. Please. Can we? Can we?
Anonymous Poster #3
11/27/2012 9:04 AM
Common! This is for the new Kingdom of Michigan Airforce Airial Refueling system and therefore a highly sophisticated military research. It is by no means homework.
What you say?
Good Answers: 114
11/27/2012 9:19 AM
It looks like homework to me. Think instead of a level pipe with ball bearings sitting inside it, at rest, when it accelerates. Now consider the case where the ball bearings are in forward motion. The result for both is given by Randall's equation in #5, above.
11/27/2012 9:22 AM
If there were air bubbles in the line, which way would they travel?
11/27/2012 11:56 PM
Oversimplified scheme:
Express the acceleration in g's, add vectorially to the vertical acceleration from gravity to get a combined static head, add/subtract pressure differential to get a total head, and finally use pipe flow data to get a flow rate.
11/28/2012 3:43 AM
Sir,
Thank you for your reply. I also got some material on this which i've attached below.
If any doubt, i'l come back to you sir.
02/25/2013 5:33 AM
Could you please tell from which book did you get this material from ?
Thank you.
Reply to Forum Thread 17 comments
Anonymous Poster (4); JohnDG (2); Joshi (2); Lo_Volt (1); lyn (2); passingtongreen (1); Pco (1); PWSlack (2); Randall (1); Tornado (1)
