Previous in Forum: Standard Belt Tensioning   Next in Forum: Cooling load calculation
ANSI B 16.5 FLANGES
05/22/2007 11:21 PM
Hi,
Can anybody send me a copy of ANSI B 16.5 Flanges Spec. Thank's a lot
Pathfinder Tags: ANSI flanges
Re: ANSI B 16.5 FLANGES
05/23/2007 11:01 PM
I think you have got to buy your own!
05/24/2007 2:05 AM
1. The correct name is ASME B16.5 (under umbrella of ANSI).
2. The site marked by Guest "2" is good to find all dimensions & weights.
3. Designing any flange includes :
a. Select the NPS and Sch. to be as the pipe line.
b. Determine the class or flange rating is based upon the Pressure-Temperature for the specified flange material, in accordance with ASME B16.5 Tables.
09/17/2008 2:19 AM
can you tell me difference between flange CLASS & SCHEDULE?
Good Answers: 61
11/11/2010 11:19 AM
The term "Class" relates to Ratings for Flanges
The term "Schedule" relates to the Wall Thickness for Pipe and Fittings
Two different things.
Do it once and do it right
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
05/24/2007 8:27 AM
Try, www.ticotitaniuminc.com
Have both blind and neck type flanges.
Dirt is for vegetables. Pavement is for racing.
11/11/2010 11:00 AM
Hi did any one sent you the ANSI B16.5 Flange spec if you got a copy can you send me a copy
Abdel Halim Galala (1); Anonymous Poster (3); PennPiper (1); unclefastguy (1)
