Previous in Forum: Fire Dept. Spring Raised Aerial Ladders   Next in Forum: Heater Drain Lines
Steam Turbine Vacuum
11/29/2012 10:40 AM
sir steam turbine condensor vacuum reading is a 20 to 22 in Hg. Hotwell level show reading 500mm. Total lavel reading 800mm. Hot well level adjust the 450 to 500mm. sir turbine condensor vacuum reading 20 to 22 inHg is ok.
Imran Butt
Re: Steam Turbine Vacuum
11/29/2012 11:07 AM
It corresponds to a condenser temperature of about 65degC. If the manual says it's OK, it's OK.
