Previous in Forum: Steam Turbine Vacuum   Next in Forum: How to Input Pump/Vessel/Compressor to Caesar II
Heater Drain Lines
11/29/2012 11:08 PM
High Pressure heater in the Feed water Line is under IBR.
Now, what about the applicablity of Drain Line from the High Pressure Heater connected to Deaerator. Does this Drain line to be considerred under IBR?
Re: Heater Drain lines
11/29/2012 11:19 PM
If it isn't, it probably should be.
11/30/2012 3:14 AM
It depends upon what the term IBR means in that part of the world.
Good Answers: 266
11/30/2012 8:22 AM
Inverted Box Rib a type of roof. I would think the whole system would be under some type of roof. I guess he has the IBR roof type.
Re: Heater Drain Lines
12/01/2012 2:50 AM
Obviously,Above Pressure 3 Kg IBR NORMS are applied and This is HP Heater.
Now, Check that Deaerator comes under IBR
If Deaerator is not under IBR Then IBR scope will be up to isolation valve on Heater Drain Line.
Or
Deaerator comes under IBr Then Drain line comes under IBR norms.
Applicability of drain line that if there is excess of water during operation which is then drain out from Heater. Insted of draining this water this can be used in deaerator as this water have more temperature than water coming in the deaerator from Dm tanks
which atomatically increase the effieincy of Hp Heater.
Register to Reply 4 comments
mhaske.dnyaneshwar (1); ozzb (1); PWSlack (1); Tornado (1)
