Previous in Forum: ENTES Network Analyzer - Wrong Data Values   Next in Forum: Control Valve
Venezuela - Member - New Member
Sour Gas Flowmeter
11/29/2012 4:02 PM
Friends,
Anyone have experiencie measuring sour gas flow to claus burner in a Sulfur Recovery unit not using ultrasonic meter?
I mean using vortex, annubar, venturi or orifice plate in order to measure the flow without problem or minimun issues
Best regards
Juan
Instruments-guy-SAV
Re: Sour Gas Flowmeter
11/29/2012 5:47 PM
Go here: Search GlobalSpec, then search for "sour gas flowmeters".
11/30/2012 10:41 AM
The simple answer is yes, but and there are many buts to overcome.
In a Claus unit the volume or quantity of H2S is extremely high, so high that it can be deadly, therefore the idea is to use instruments where the possibility of leaks are zero, since even small leaks will cause corrosion and health issues, so based on this main issue instruments which do not require contact with the product are ideal.
Register to Reply 2 comments
