Previous in Forum: Implementing a Control System   Next in Forum: How to Calculate Transformer Losses
11 comments
How to Calculate the Number of Poles in a DC Generator
11/29/2012 9:55 PM
How do I calculte the Number of poles in a DC Generator. The question I need to aneser as given me some data but not all. I have 400 V dc, 600rpm,80 effective conductors, 250mWb flux per pole. How/what is the formula to calculte number of poles?
Pathfinder Tags: calculate DC generators poles
Re: How to I calculate the number of poles in a DC Generator
11/29/2012 10:12 PM
Where have you looked, so far?
Why do you want to know?
11/29/2012 10:24 PM
I have tried many google searchs and even read through the text book supplied with my course but there is to example for me to go of. I need to no the formuala to calculte how many poles in a DC generator.
11/29/2012 10:35 PM
11/29/2012 10:40 PM
Thanks I think I found the formula that I need. Many THANKS
11/29/2012 10:43 PM
That formula I dont thik will work as I dont no the number of ploes to use,The formula was f =pn/120. I dont have the poles so how can I use this?
11/29/2012 10:52 PM
I think each pole would have 2 conductors, hence 80/2 = 40 poles.
(Synchronous applies to AC rather than DC.)
11/29/2012 11:07 PM
Now I am just more confused...sorry :)
11/30/2012 12:45 AM
Hello jesseryanwarren ,
The formula for generated voltage in a generator is given as
WHERE Eg is the generated voltage
Ø is the flux per pole
Z is the total number of conductors
N is the speed in rpm
P is the number of poles
A is the number of parallel paths
In a simplex wave winding A is 2
and in a simplex lap winding A is same as the number of poles
Let us assume the above generator to be a simplex wave wound one .
Hence Eg = ( ØZNP )/(2*60)
substituting the value we get P = 4 poles
SIBIN
Good Answers: 42
Re: How to Calculate the Number of Poles in a DC Generator
11/30/2012 9:32 AM
As Sibin already explained
the DC machine number of poles is not related directly to machine velocity [rpm].
Indeed the EMF=N*p/a*n*Fi where:
N=total number of turns ;p= pole pair number a=the rotor current parallel ways and Fi=the single turn magnetic flux.
But the number of poles is chosen according to technological reasons [heating-cooling, ventilation and so on].
For rotor diameter less then 40 cm -4 poles is usually recommended.
For rotor diameter less then 70 cm will be 6 poles
For up to 120 mm 8 poles and for more 10 poles.
Then Fi=pi*D/2/p*li*B where pi=3.1414….D=rotor diameter; li=rotor length; B=Magnetic Flux Density in the machine gap.
The AC machine frequency could be [usually] 50 or 60 Hz. But DC machine frequency is [usually] 25 up 75 Hz -for small diameter up 75, for large diameter only 25-in order to reduce the laminate losses
Julius
Good Answers: 42
12/01/2012 2:39 PM
Correction:
Sibin formula is correct. In my relation N it is number of active conductors [and not the number of turns as I said] and n=rpm/60 [rps] of course. Since EMF could be 5-10% more than generator terminal voltage p= (approx.) 2 and 2p=4.
Julius
12/02/2012 3:30 AM
That 'N' is just for an indication
Register to Reply 11 comments
7anoter4 (2); jesseryanwarren (4); lyn (2); Sibin (2); Tornado (1)
