Previous in Forum: Generator Protection in Neutral and Line   Next in Forum: Under Voltage Problem at DG Sets
9 comments
Increasing RF Modulator Power
12/02/2012 12:10 PM
Is it possible to modify an RF modulator to give out higher RF power? I have one from a Playstation 2. I can get a range of a few cm from it but I was wanting a few meters. Are there resistors that can be removed?
Good Answers: 444
Re: Increasing RF Modulator Power
12/02/2012 11:16 PM
Probably not. You're assuming that the resistors are somehow limiting the output signal, they're not. RF modulators do not have a typical RF amplifier output stage with tuned circuits to couple the RF energy to an antenna. Instead they are intended for direct connection to the input stage of a tuner that expects only microvolt/microwatt signal levels from an antenna, therefore their output power is commensurately much lower than broadcast strength.
You could buy a linear RF amp and run the modulator through it to an antenna, but by the time you go through that expense it would be much cheaper to buy one of these. I hope you enjoy all the email that they send you.
12/03/2012 9:54 AM
No you can't but you can feed the low RF modulator signal to an RF power amplifier stage with same frequency of the modulator and the same output impedance (50 OHME) the stage (circuit) consist of one transistor called booster .
12/03/2012 10:15 AM
( ( (( [YOUR DEVICE] )) ) ) ~ ~ ~ ( ( (( [Bi-Di RF Antenna] )) ) )
This is the external standalone module to be added
Hi-Fq signals are easy to shift to another Fq just by setting the device to consume more(/less) power from what it's designed to ... ec. ec.
ci139
Good Answers: 59
12/03/2012 8:22 PM
Yes, You Can!!
By reducing said resistors the reach increases, and its life expectancy decreases.
Use it sparingly (1% duty cycle, 10microsec bursts each), and your reach might be increased 10 - 100 fold. Please contact radar specialists for details.
And worrying about exceeding FCC limits? You will find it out in due time. Why worry, before the so-called due time comes?
12/04/2012 6:05 AM
I burnt out the ps2 modulator. I tried again with an old Astec modulator and I managed to get much more power. The signal was appearing at around 580 Mhz and I could get a strong signal from the other end of my room. There is a resistor that I can lower the value of for even more power.
Good Answers: 444
12/04/2012 11:45 AM
Good for you. Please post when you burn out that one too!
12/04/2012 3:03 PM
It still works and can now transmit through the whole house. It does not even heat up in the slightest.
12/05/2012 9:55 AM
Why it is working right now while the others have been burned??.
12/06/2012 1:23 AM
Because it is a much older design which does not use an IC for the modulation. I believe a colpits oscillator is used.
Register to Reply 9 comments
caeser (2); ci139 (1); hydrogenhead (3); leveles (1); RAMConsult (2)
