Previous in Forum: Steam Turbine Rolling   Next in Forum: Question About Drying Theory
Compressor Turbine
12/03/2012 8:18 AM
Dears All
I want to know what is Compressor Turbine (CT) , the department that located in end of GG in gas turbines? and what's it application?
Thanks
Pathfinder Tags: ct
Re: Compressor Turbine
12/03/2012 8:24 AM
12/03/2012 9:54 AM
Lyn's link answers your question most broadly. Was there anything specific in particular you wanted to know / ask?
The first law of thermodynamics is you do NOT talk about thermodynamics.
12/03/2012 1:06 PM
In a compressor turbine the shaft of compressor and turbine is common. basically its a case of gas turbine plant...where power is devloped by this turbo compressor concept
"No matter how hard the past,you can always begin again."
12/04/2012 2:49 AM
But in some gas turbine there are two separate shaft ( double shaft) , and in end of rotor compressor located two or more disc and stator that names CT (compressor turbine) , even in single shaft is too.
this department is located in hot section too , instead rotor compressor that located in cold section.
Register to Reply 4 comments
Farid (1); lyn (1); Mizuti (1); vir540 (1)
