Previous in Forum: Common Bearing Material Combination   Next in Forum: Compressor Turbine
Steam Turbine Rolling
12/02/2012 11:36 PM
During rolling of turbine if the HP expansions start increasing (HPT) what are various ways to control it?? considering ( its a cold rolling casing temp less than 150deg) tht all proper drains of turbine r open and inter layer heating is charged??
"No matter how hard the past,you can always begin again."
Re: Steam Turbine Rolling
12/03/2012 3:54 AM
This subject is ideally the basis of a telephone call to the turbine manufacturer's technical helpline.
12/03/2012 12:59 PM
In the manual provided its mentioned that proper soaking of turbine to be given...anything else can be done to bring expansions within limits ??
12/03/2012 1:59 PM
A natural wear in period perhaps?
What does the manufacturer say? No point us offering specialised suggestions here that could damage your turbine (whatever it is) without more information on your particular turbine.
12/04/2012 9:04 AM
When all else fails, contact the OEM after reading (carefully) the manual(s).
The thing to ask them is at what steam pressure on the boiler you should begin warming up the turbine. Too early (too low pressure), and you are looking at condensate impingement (my own belief), too high a pressure (and temperature) and you will heat up too rapidly, expand the metal in an uneven manner, and could very likely damage the unit.
Register to Reply 4 comments
jack of all trades (1); James Stewart (1); PWSlack (1); vir540 (1)
