Previous in Forum: How Coal Mine Fiber-optic Camera Works in Dark When There is No Infrared Light?   Next in Forum: Galing On Drill Collars Threads
Thermocouple Construction of Type T Bare Wire
12/03/2012 11:57 AM
In doing an in process quality check of type T stock bare wire, I am trying to make a thermocouple of type T construction and 36AWG and testing for special limits conformity. Is this feasable?. 36 AWG wire is so fine, there may be issues of metal fatigue and cold working of the wire that would cause it to read out of spec. for special limits because of the fragile nature of 36AWG. Is it possible the out of spec readings are caused by these issues?
Good Answers: 176
Re: Thermocouple Construction of Type T Bare Wire
12/03/2012 3:06 PM
I only use commercial T/C's, I don't roll my own, so I don't have an answer to your question about the source of the error, other than wire alloys can vary.
I'm curious as why, if you have calibration equipment (including a ice point/cold junction) that is good enough to determine that any particular T/C is outside the published limit-of-error, why not use the error as a correction factor for that given thermocouple? You've gone to the cost and effort of determining the error, use it.
12/03/2012 3:58 PM
Hello and Thanks, We are manufacturing it and it must be made to special limits, which for type T is quite constraining (.5 degrees C). We cannot correct except to choose a different lot number of bare constantin to pair up with the positive copper leg. Trying to make a TC out of bare 36 AWG wire is a nightmare in itself, a job for a microsurgeon, and I'm afraid we may be killing the patient, (the wire). I'm wondering how resilient our patient is (the 36AWG copper and the 36AWG constantin).
12/03/2012 10:51 PM
One thermocouple welder I saw went up to 1.1 mm wire, but it didn't say how small it could go. Maybe a search on various models would turn up a good choice.
12/04/2012 12:27 AM
Register to Reply 4 comments
Iris (1); John Fahey (1); lyn (1); Tornado (1)
