Previous in Forum: Short Circuit Rating of Cable   Next in Forum: European Equivalent to IPC2221 PWB Design
11 comments
Ring Main Unit
12/06/2012 5:52 AM
Attention for Electrical engineer who Developed/Designed Electrical Infrastructure for Integrated township Development.
Dear guru Let us consider,From local electricity board we are getting power for our Development. According to the local Electricity rules upto certain demand load,The Electricity board giving 11kV or 66kV or 110kV line respectively.If suppose we are in need of 110 kV(Local electricity board) because of more demanded load in our Development.From local electricity board they will give 2 nos of 110 kV power line for Receiving station (which will be designed and developed by Electricity board in the place of our Development).RMU can be connected for 110kV voltage level .Likewise can we maintain that RMU scheme in 11kV voltage level?.If yes send me the scheme.
Note: I have a diagram which having RMU scheme only in 110 kV line not in 11kV line
Pathfinder Tags: Ring main unit
Good Answers: 181
Re: Ring Main Unit
12/06/2012 8:36 AM
Re: Ring Main Unit
12/06/2012 9:50 AM
Re: Ring Main Unit
12/06/2012 1:40 PM
Short answer is obviously no for both homework/general interest questions. A substation is not some black box that just takes one voltage and spits out another using ohms law.
Good Answers: 42
Re: Ring Main Unit
12/06/2012 2:13 PM
When your Factory or township is fed from two different substations of Public Electricity Board ( Government or Corporation) or Private Electric Company they make a ring main system for the benefit of both the supplier and the customer. But if two interdependent feeders are extended to the customers premises from single source( same substation) it is for the customer to design their own suitable ring main system for their benefit depending on the load pattern, distribution system, location of the substations and the available financial resources. If you want total capacity single ring main then the cable network has to cater for full capacity of the connected load of the customer which is a costlier design. Instead you can have two different ring main systems . You can have half the substations on one side of the bus with first incomer and other half with the second incomer and have a bus coupler in the middle. So the design will depend on local conditions.
Re: Ring Main Unit
12/06/2012 2:48 PM
Are you installing one substation or two, not that it matters. You are given a maximum demand from the Electrical Board. Your job is to ensure you do not exceed that demand. It does no matter which side you monitor. IF you have 2 subs there is equipment that will allow you to integrate the demands of both to obtain the total maximum. I would think the 11 kv side would be cheaper.
Re: Ring Main Unit
12/07/2012 1:14 AM
If the rated voltage of equipments like motors in the factory is 400, locate package substations(11kV/400)around the factory.
pnaban
Re: Ring Main Unit
12/07/2012 1:46 AM
See Mr. Muthuvel,
u have asked yes or no questions - "RMU can be connected for 110kV voltage level" - YES it can be connected.
"Likewise can we maintain that RMU scheme in 11kV voltage level" - YES it can be maintained in 11KV RMU.
i cant able to understand the meaning of "SCHEME" wheather u are asking the detailed / complete ring main grid / circuit with all specifications?
Shaju Khan
Re: Ring Main Unit
01/17/2013 1:51 AM
Dear Mr.Shajahan
If you can connect RMU in 110kV voltage level and 11kv in same substation.Kindly send me the that Single line diagram of the sub-station from 110kV voltage level to 11kv voltage level(note:that sub-station should be approved and executed without any problem)
Re: Ring Main Unit
12/07/2012 4:35 AM
Re: Ring Main Unit
12/07/2012 8:45 AM
RMU is available up to 22-34.5 kV.
France - Member - New Member
Re: Ring Main Unit
12/10/2012 8:00 AM
I do not see how, even with 110KV available, you can do without a 11 KV (or 22KV or even 36KV - as in Spain) loop, on which you will connect MV/LV transformers with RMUs.
Register to Reply 11 comments
Drton (1); iftikhar129 (1); jack of all trades (1); Muthuvel (1); obouill (1); pnaban (1); PWSlack (1); TonyS (1); user-deleted-1076 (1); V.I.Abraham (1); wareagle (1)
