Previous in Forum: Pump Reduced Pumping Rate   Next in Forum: DIN 16901 Tolerance for Plastic Molding
16 comments
Piping Engineer
12/10/2012 2:49 PM
what is the maximum height we can go for a pipe to be transported ?
Good Answers: 104
Re: piping engineer
12/10/2012 2:52 PM
Just a little below the lowest obstruction along the route it must take. Could you elaborate just a little?
Re: Piping Engineer
12/10/2012 2:55 PM
The M25 motorway is regularly used for transporting concrete water pipes - in both directions, it would seem. Why the hauliers cannot get together and save all the unneccessary mileage is a complete mystery.
Re: Piping Engineer
12/10/2012 3:35 PM
I have always felt that way here in the U.S. of setting up a website where the clients can use to put up a request truckers can join for for a nominal fee, so they can eliminate running a dry load.
Customers can post a RFQ, with the discription (size, weight, date, ect...), pickup/distination
The truckers would have to satisfy the requirements, insurance and permits, as well as listing their requirements as an example of certian radius for pickup/distination.
This could be hooked up with hubs, for logistics.........., so that there may not be a direct haul because a trucker may not have all the permits between states.
Re: Piping Engineer
12/10/2012 2:56 PM
I'd imagine that is determined by the method in which you'd like the pipe shipped. Are you using a freight train, cargo ship, or some other means? If you're buying from a manufacturer, they typically have methods of transporting the goods and can help you further. If you're shipping off your own pipe, take a look at some of the top links from this Google search and consider giving them a call to see about rates and capabilities.
The first law of thermodynamics is you do NOT talk about thermodynamics.
Re: Piping Engineer
12/10/2012 3:00 PM
Undefined: "we".
It depends upon where "we" are and how "we" want to transport and assemble it.
If, for example, one were inside the Northern Line of the London Underground system and the only route were along the line, then for a pipe of circular cross section about 5ft diameter would be the limit.
If one were flying pipes inside one of the most modern freighter aircraft, then there are aircraft that can fit inside other aircraft, so the maximum diameter would be about that of a Boeing 747 aircraft.
If the pipe were to be delivered in prefabricated sections and assembled inside the tunnel, then there is no theoretical limit to the diameter, reference the two crossover caverns inside the Channel Tunnel rail link that joins England and France.
Re: Piping Engineer
12/10/2012 4:45 PM
This would have geographic implications. Regulations are different, depending on where on the planet the pipe is.
This would change too, if the pipe is being transported by airplane.
In the USA, the Interstate Commerce Commission and state agencies would specify the height restrictions for ground transportation.
Air transport is regulated by the Federal Aviation Administration, and, perhaps the International Air Transport Association.
Re: Piping Engineer
12/10/2012 4:46 PM
By road?
By train?
By air?
From where to where?
Please provide more information.
Re: Piping Engineer
12/10/2012 5:14 PM
In an airplane, about 38,000 feet.
Re: Piping Engineer
12/11/2012 5:11 AM
The mode of transportation and what is geographical feature of tht region were it would be carried depends...!!
"No matter how hard the past,you can always begin again."
Re: Piping Engineer
12/11/2012 1:31 PM
what is the maximum height we can go for a pipe(flow in pipe) to be transported ?
Re: Piping Engineer
12/11/2012 1:41 PM
Good Answers: 179
Re: Piping Engineer
12/11/2012 1:32 PM
To ship an oversized pipe section, one would employ the Super Guppy, a heavily modified C-97 transport.
NASA's contractors used to ship Saturn V (or is it IV?) sections that way....
Good Answers: 179
Re: Piping Engineer
12/11/2012 1:36 PM
Re: Piping Engineer
12/11/2012 1:41 PM
iam just a beginner here iam asking
what is the maximum height we can go for the flow in a pipe line to be transported if the pipe line is on road and the distance is about 10km pipe line and above
elaborate it please
Re: Piping Engineer
12/11/2012 1:42 PM
Depends on so many unknown factors you have not given that no one can answer it.
If you mean elevation, that depands on the pum[, among other things.
You should speak to a local engineer who MAY understand what you are really asking, we don't!
Re: Piping Engineer
12/11/2012 4:19 PM
Also, you should be doing your own research for interviews.
We won't be there to tutor you during the interview.
Register to Reply 16 comments
Anonymous Poster (1); bigg (1); CaptMoosie (2); jack of all trades (2); lyn (3); Mizuti (1); phoenix911 (1); PWSlack (2); srikanth madamanchi (2); vir540 (1)
