Previous in Forum: Fixing Corten Steel Panels   Next in Forum: Neutralising Carbon Monoxide In Mine Shaft
16 comments
Use of Oxide Containing 38 % Fe & 8 % Titanium
12/11/2012 9:03 AM
I have source of a material having 38-40 % Fe & 8 % Titanium. It is dark brown powder.
I want to know the use of this material . I think it is an ore
Please guide
Pathfinder Tags: Fe & Ti Ore
Re: Use of Oxide containing 38 % Fe & 8 % Titanium
12/11/2012 9:26 AM
It's rust. Until the other 52-54% is known about, of course.
12/11/2012 9:36 AM
You will have to have a complete analysis.
Smelt some and see what you get.
Good Answers: 61
12/11/2012 9:56 AM
Any idea what the remaining 50+% is?
12/11/2012 10:14 AM
I have given it for testing. meanwhile can this material be melted in Electric Arc Furnace
12/11/2012 10:26 AM
Until the remaining 52-54% is known, the forum cannot answer with any certainty. Do have a go, though, and report back with the outcome.
12/11/2012 10:30 AM
Having unknown materials on site could be considered as running contrary to the CoSHH Regulations. How would anyone know, for example, that the 52-54% wasn't Polonium 210 or Plutonium 238?
12/11/2012 10:40 AM
Or Kryptonite?
12/12/2012 1:32 AM
or aluminum powder....thermite anyone?
12/12/2012 11:12 AM
Wow! Smelting that would be spectacular!
(Been there, done it, etc.)
12/11/2012 11:46 AM
The remaining 52% to 54% is undoubtably unobtainium
Good Answers: 145
12/12/2012 9:32 AM
The other day we had a design where the BOM contained 27% unobtainium. Since this material is 52% to 54% unobtainium can I get some of it, thin it down and use it?
Re: Use of Oxide Containing 38 % Fe & 8 % Titanium
12/12/2012 9:35 AM
The souce of this material would have a strong bearing on the content- if it is sourced from a ground site it could be any of many earth type minerals, Silica, aluminum, calcites- is it magnetic-if so it could be a titaniferous magnetite and these also carry many odd elements incorporated or chemically bonded. An assay lab is the best answer- how did you determine the Fe and Ti content without identiyfing any others
12/12/2012 10:25 AM
The company which gave the material had said the contents. Yes it is magnetic (Weak)
Can u tell me what it is. Can it be used for Ferro Titanium
12/12/2012 10:32 AM
...then contact the company, ask what the rest of it is, and ask for a Material Safety Data Sheet for it! Why involve CR4 readers in guessing games?
12/12/2012 10:33 AM
No matter how many times you ask, the answer will not come from this forum.
Have it analyzed.
12/12/2012 10:45 AM
To give you a definative response I would need to know where it came from - not necessary to disclose exact for security reasons but if it is an ore, the siting as to value and content is important- very possible to use as ore for both titanium and Iron dependent on extractive capabilities- I have some knowledge of these ores and some carry precious metals as well
Register to Reply 16 comments
anishsigtia (2); BruceFlorida (1); Deefburger (1); energyconversion (1); Hugh Sutherland (2); JPool (1); lyn (3); PWSlack (5)
