Previous in Forum: Analog Signal Voltage Levels   Next in Forum: Dell Precision M6500 Problems
Location: kampala uganda, work with alam group of companies,sugar and allied industries ltd as electrical engineer.
Regulated Voltage After Chopper Transfomer in 14 Inches Coulor Television
12/11/2012 2:12 PM
what are the secondary voltages in 14 inches color TV after the voltage chopper transformer and what specific ccts are these voltages to supply say like vertical sweep cct, cathode tube heater voltage
Re: Regulated voltage after chopper transfomer in 14 inches coulor television.
12/11/2012 2:14 PM
If you have to ask, LEAVE THE BLOODY THINGS ALONE!
Re: Regulated Voltage After Chopper Transfomer in 14 Inches Coulor Television
12/11/2012 5:26 PM
Not sure about the other voltages, but the cathode heater voltage is low. I seem to recall it's typically 6.3 volts.
You could probably find the values you're looking for on the 'interwebs'.
Good Answers: 444
12/11/2012 8:05 PM
I'm not sure why you didn't Google this yourself, if you had you would have seen this:
http://www.ti.com/lit/an/snla017/snla017.pdf
No more questions will be entertained until you report back what is the page number in this document that has your answer.
Register to Reply 3 comments
Anonymous Poster (1); RAMConsult (1); Usbport (1)
