Previous in Forum: Screw Compressor Thrust Bearing Frequent Sudden Failure   Next in Forum: ASME Tolerance for Machining
8 comments
Pipe Material For Severe Cyclic Condition As Per ASME B31.3
12/12/2012 4:24 AM
Is it MANDATORY that we have to select pipe material which is listed in ASME B31.3,305.2.3 for severe cyclic condition?
Anonymous Poster #2
Re: Pipe Material for severe cyclic condition as per ASME B31.3
12/12/2012 4:29 AM
Not if you don't want it to last.
12/12/2012 4:39 AM
ASME B31.3 clause 300(4), "Piping elements should, insofar as practicable,conform to the specifications and standards listed in this Code. Piping elements neither specifically approved nor specifically prohibited by this Code may be used provided they are qualified for use as set forth in applicable Chapters of this Code".
ASME B31.3 ,305.2.3 "Pipe for Severe Cyclic Conditions. Only the following pipe may be used under severe cyclic conditions".
Unfortunately I couldn't find any 'shall be' used!So,I am confused.
Anonymous Poster #2
12/12/2012 4:46 AM
Do you want it to last, or do you want it to burst?
12/12/2012 5:58 AM
We have developed new materials .After rigorous testing we found that those materials are superior in mechanical properties than the listed materials in ASME B31.3 specified for severe cyclic. So,can we use the new materials in accordance with ASME B31.3 clauses?
Anonymous Poster #2
12/12/2012 7:05 AM
Who is liable when it all goes wrong?
12/12/2012 8:03 AM
In both cases, ASME is not responsible!
Anonymous Poster #2
12/12/2012 8:15 AM
Is that why you're remaining anonymous?
12/12/2012 7:29 AM
This is actually a question about risk. One answer is in itself a question, albeit a rhetorical one:
  • Who in their right mind would select for severe cyclic condition a material advocated by an anonymous poster to an internet website when that individual could select a proven material in ASME B31.3, 305.2.3 with known provenance and the confidence that goes with it?
