Previous in Forum: Droop Control In Steam Terbo-Generators   Next in Forum: Pipe Material For Severe Cyclic Condition As Per ASME B31.3
24 comments
Screw Compressor Thrust Bearing Frequent Sudden Failure
12/11/2012 6:45 PM
there is a big lubricated screw compressor in our site that compresses propylene and is always dued in full load , it frequently (about every 6 monthes) damages burns the male shaft thrust bearing quite sooner than normal L10 life of bearing, it utlises balance piston on both shafts to reduce thrust load on bearings, the problem occurs suddenly without any warning sign in vibration or bearing oil temperature logs , just with a sudden big knok sound. oil analysis show no specific abnormality either. our second same compressor that is dued on part load works fine without such problem any suggestion would be appreciated
Good Answers: 21
Re: Screw Compressor Thrust Bearing Frequent Sudden Failure
12/11/2012 9:19 PM
What does the manufacture have to say? Have you contacted them about this condition.? The reason I ask, is it is very hard to trouble shoot this kind of problem using the written word. You need someone on site who can touch feel and suggest.
12/11/2012 10:28 PM
Is there a way it could be getting liquid in the suction?
12/14/2012 8:40 AM
since the suction line is set to higher pressure than atmosphere and evaporator side pressure and temperature is carefully controlled there is no way for liquids to exist in the circuit the same results came from oil analysis
12/11/2012 10:44 PM
I would suggest you to maintain a logbook and take reading at regular intervals. After this please check that if bearing is properly installed. Is there any kind of vibration which is coming at a certain period not at regular interval...also bearing damage can take place due to sudden overloading or at times due to inadequate oil flow due to leakage or oil/water path to bearing cooling getting blockd.
"No matter how hard the past,you can always begin again."
12/14/2012 9:02 AM
as i mentioned before all vibration and temperature logs and observations shown no abnormal condition , the thrust bearing oil temperature logs also was normal that one may conceive no alignment issue , but the last thing is what happens really and im suspicious about. what causes a sudden overload on a thrust bearing while there is no leakage and the separator oil level logs show normal , can you explain what can cause oil path blockage, i was more thinking of balance piston malfunction but had no idea how and why
12/12/2012 3:27 AM
Get the manufacturer's representative in to have a look at it right now. These individuals may have seen the problem elsewhere and will be in the best position to help fix it. After all, these people have a commercial reputation to maintain; CR4 readers don't.
Good Answers: 266
12/12/2012 8:16 AM
I do notice that you have compared two like compressors. The one on which you have stated as less the full load works fine. The one that is used at full load fails. Possibility is that what you have is an over load on the one that fails.
12/14/2012 9:11 AM
since the full output power of drive system is less than full load power draw of comp. its nonsense to have compressor to go under excessive load
12/15/2012 4:24 PM
the sys dont need to exceed it's specified load to start failing -- if it's utilized 24-7 ... you start to notice where manufacturer's specs don't hold
ci139
12/12/2012 10:27 PM
Just check the quality of propyle both at the inlet and out let if there any diferrences compared to other compressor you have. Could also be liquification of the same.
Best Regards, Shivaram
12/14/2012 11:09 AM
both compressors work parallel in a single circuit
Good Answers: 52
12/12/2012 10:28 PM
12/14/2012 11:22 AM
this link is filtered by my ISP, im trying to bypass the filteration to see inside , itd be helpful to give some mirrors or proxy server address
12/13/2012 2:52 AM
What are the findings on the failed bearing, balance piston and screws? Any major deviation of operating parameters? Oil quality. Is it beyond doubt ok? What type of bearing it is? Are you using same make bearing in both compressors?
12/14/2012 11:59 AM
the thrust on the male shaft is burnt dark blue and nearly melt but no significant problem on balance piston but the head of screw badly rubbed to the casing to produce deep grooves that i can say for sure it occurred just after thrust bearing failure , the bearing used were not same make but fully satisfied manufacturer specifications and approved by them
12/13/2012 8:07 AM
(1) Check with manufacturer of the machine as they have much more combined experience with their product.
(2) After repair trend the machine with ultra sound for the simple reason ultra sound signature is predominately the first indication of things going wrong.
(3) Since you have a sister machine you may as well trend that machine as well to try to ascertain any variations in the two machines. They should be similar but not necessarily identical.
12/15/2012 11:38 PM
i didnt get you in 2nd sugg. , what sort of test it is can you please give me more info or a link to find more about
12/16/2012 7:17 AM
There are three main indicators of problems. #1 is ultra sound , #2 is heat and # 3 is vibration unless the failure is catastrophic, ( sudden with no warning ) Ultrasound appears to be almost always the first signature of imminent failure or issues. Anything that moves makes sound and if inaudible then it is ultra sound usually under 20,000 in frequency. Your cat or dog may be able to hear it but humans do not. Companies such as UE and SDT make good ultra sound detectors that convert ultra sound into audible sound. Every owner of machinery should have this diagnostic tool along with thermal imaging and vibration testing if they are serious in preventing expensive damage.. Most managers are unfamiliar with ultra sound diagnostics and appear to write it off due to their ignorance. Trending is taking a reading at the same spot under similar conditions (temperature) and recording same for future reference,reading of monthly or weekly work well and if changes happen quickly then step up to daily or even hourly depending on equipment, as sound increases it should be a warning of imminent failure if taken seriously. Look up one of the companies mentioned ( not an endorsement ) they have all the information you need.
12/13/2012 12:52 PM
i'm not a production tech -- however
you never described the failed bearing (most bearings i know failed - and there are 2 or 3 - are due water or moist)
the abrupt failure may indicate constant overload - from the shaft side - 5deg from axes something ... may and not
speculation - the full load wears inequalities to roller path >> heat >> expansion >> blow
ci139
Good Answers: 19
12/13/2012 7:56 PM
It sounds like you are getting a liquid slug.
12/18/2012 11:04 AM
what sort of slug may occur in the refrigerant circuit pipe line if its terrain slugging what would be that liquid to make a plug and after all how a periodic slug would cause a sudden over thrust on the comp. shaft
12/18/2012 8:12 PM
((((I dunno even what the machine looks like you're talking about))))
anyways certain oil metal can act as acid metal (why dont you use ®bearings)
ci139
12/15/2012 2:08 AM
Burnt bearings may be due to overloading or lack of lubrication. Compare it with the good running compressor. Are the bearings and balance piston identical in all respects? The rubbing of the screw with the casing may have occurred only after bearing failure.What is the sealing between bearing and system fluid? Any chances of failure of the seal. Is the balance piston able to take care of the thrust load?
12/18/2012 11:22 AM
there is no special sealing but accurate designed tolerances to let lub oil( that is pumped to higher pressure than discharge) to escape from bearing casing into screw area and mix with refrigerant
Register to Reply 24 comments
ci139 (3); fixitorelse (1); IRSHAD (2); ozzb (1); PWSlack (1); Relativity PL (1); roy hammy (2); saeid7812000 (9); shivaganti (1); Stedou73ish (1); Tornado (1); vir540 (1)
