Previous in Forum: NACE RP & SP Difference   Next in Forum: Screw Compressor Thrust Bearing Frequent Sudden Failure
Droop Control In Steam Terbo-Generators
12/11/2012 7:18 AM
What is Droop Control?
How that can work on all mode ie speed,load & pressure control mode?
Droop % is less, governing is more sensitive, then why use it?
Re: Droop Control In Steam Terbo-Generators
12/11/2012 7:20 AM
http://en.wikipedia.org/wiki/Droop_speed_control
Nothing to do with any brewery.
Good Answers: 104
12/11/2012 9:50 AM
Go to this location: http://www.woodward.com/searchpublications.aspx , and search on 'droop' for some good information from the Woodward company, a reputable governor manufacturer.
12/12/2012 4:52 AM
Dear Mr.shshkntyrm,
DROOP CHARACTER 9of Speed) is relating to the Governor of a Prime Mover, be it turbine, Diesel Engine etc and expressed in percentage and ameasure of Drop in Speed from NO-LOAD to FULL-LOAD
Thus (SPEED at No-Load) - (Speed at Full-Load) * 100/ (SPEED at No-Load)
This eseentially to be accounted while Synchronising for Load-Sharing.
In the same way the DROOP CHARACTER for Alternators - in Electrical side is calculated.
DHAYANANDHAN.S
Register to Reply 3 comments
bigg (1); dhayanandhan (1); PWSlack (1)
