Previous in Forum: SIF = Fracture Toughness?   Next in Forum: Surface Linear Indication
12 comments
Please Assist with Homework Assignment on Fracture Mechanics!
12/16/2012 2:09 AM
Hi! I need some guidance on my homework on fracture mechanics. Thanks in advance!
A cylindrical pressure vessel in an ammonia plant was in service for 16 years before it exploded into a large number of fragments. The vessel was 7 m long with internal diameter 1 m and a wall thickness 62 mm. The normal operating pressure gave rise to a wall stress, whose maximum value was 285 MPa with a service temp 26C.
The material was a low alloy steel with a specified minimum yield stress of 570 MPa and a carbon equivalent of 0.56. The design of the vessel required a min Charpy impact energy value of 35J for the steel plate.
All the fractures were flat, the micro-mechanism of fracture was cleavage. The failure was due to the catastrophic propagation of semi-circular thumbnail cracks, 4 mm deep at the edges of a series of fillet welds used to attach internal fittings to the vessel wall. Tests on samples of the material around the welds gave a Charpy impact energy value of 11J. The gas in the vessel contained 58% hydrogen and an analyses of the steel showed 0.4% free hydrogen in interstitial solid solution.
I need to account for the failure using fracture mechanics! Please any guidelines in which direction i should move in this assignment would be highly appreciated!
Good Answers: 34
Re: Please assist with homework assignment on fracture mechanics!
12/16/2012 5:46 AM
Thank you for being honest. But friend, CR4 frowns on homework questions. What does your mentor say? What do you say about discussing among your peers/mates/seniors?
12/16/2012 8:55 AM
Joshi's right, we don't do homework.
Here's some background you might find helpful.
Introduction to Fracture Mechanics - MIT
12/16/2012 10:07 AM
Check also into hydrogen embrittlement.
12/16/2012 12:19 PM
Was this vessel Post Weld Heat Treated? I am (I have not read any answers yet) betting on hydrogen stress cracking caused by improper or lack of PWHT.
12/16/2012 12:23 PM
Didn't read the question, either, did you?
It's homework.
12/16/2012 2:04 PM
It should have been heat treated but no records or any other evidences are available.... So one may assume that there was no PWHT. Do you think it may be one of the causes of the failure?
12/16/2012 12:55 PM
This sounds like a real vessel, rather than homework. It is not a run-of-the-mill ammonia refrigeration vessel; the pressure and wall thickness are much higher. What is the full range of pressure and temperature conditions in the vessel? The Charpy requirement seems odd for 26°C. The wall thickness does suggest PWHT, as already noted.
12/16/2012 1:12 PM
Even if the thickness did not require PWHT the sevice would require it.
Good Answers: 137
12/17/2012 5:02 AM
Sounds like a vessel for ammonia synthesis, Haber or similar process. Similar because pressure calculates to ~ 350 bar which is bit high for Haber, unless I'm out of date. Though according to Wiki the temperature used for ammonia synthesis is 300 - 550°C, not 26°.
But working pressure 285 MPa seems very high for a vessel containing compressed gas, even at 26°C. From memory, usual figure for low-alloy steel is ~ 170 MPa. If it was a real failure, I wonder how many people were killed?
12/20/2012 1:55 AM
Gents, any ideas? Or maybe it is difficult task?
Good Answers: 34
12/20/2012 2:55 AM
There are many hints, scattered on this thread, if only you could apply your mind, you may go places.
Good Answers: 137
12/20/2012 8:27 AM
Several suggestions have been made. Have you followed them up? What's the story behind the temp/pressure? Is it on ammonia synthesis, maybe upstream of the main reaction vessel?
It might be worth reading a book by Prof J.E.Gordon called The new science of strong materials. It's unlike any other book I've read about strength of materials. It might help and in any case it's an interesting read. ISBN 0-14-013597-9.
Register to Reply 12 comments
Codemaster (2); jmart23 (2); Joshi (2); lyn (2); Sergey Volkov (2); Tornado (2)
