Previous in Forum: 2004 Chevy Malibu ABS Light Problem   Next in Forum: Lift Strut Repair
How to Set the 6 Cylinder Engine Timing
12/17/2012 3:02 AM
i want know the timing setting on 6 cylinders engine please any one say detail
Re: how to set the 6 cylinder engine timing
12/17/2012 3:11 AM
Yes. Obtain a copy of the Haynes Manual for the engine. It will be found within.
12/17/2012 3:12 AM
Depends on the engine. Somewhere from 0-12° before top dead center. They're all different.
Look it up!
12/17/2012 4:47 AM
start by stating the year and size of the engine, what type of car????? do you have a timing light?
Re: How to Set the 6 Cylinder Engine Timing
12/20/2012 1:20 AM
Well, if the vehicle is older it will be on a label on the radiator shell. Otherwise a Haynes or Chilton's manual. Or provide make, model, displacement, etc so we can Google it for you.
common knowledge...less common than common sense
Register to Reply 4 comments
Fredski (1); lyn (1); PWSlack (1); The.Tinkerer (1)
