Previous in Forum: Clarification Regarding Oversizing of Transformer   Next in Forum: Capacitor Capacitance Checking
9 comments
Inverter vs UPS
12/19/2012 3:34 AM
What is the difference between an inverter and UPS ?
Good Answers: 34
Re: Inverter vs UPS
12/19/2012 3:46 AM
It will help you in life, if you learn how to Google. I put your question to Google & you can see the result now. It takes much less time than the route you are following.
Re: Inverter vs UPS
12/19/2012 3:50 AM
They do different jobs, as anyone who has looked at their article pages in Wikipedia will know already.
Re: Inverter vs UPS
12/19/2012 6:31 AM
An inverter is the opposite of a converter, UPS delivers packages.
Re: Inverter vs UPS
12/19/2012 8:04 AM
You can interrupt an inverter, but not a UPS.
Good Answers: 804
Re: Inverter vs UPS
12/19/2012 9:28 AM
Ever hear the maxim "All squares are rectangles, but not all rectangles are squares"?
Good Answers: 11
Re: Inverter vs UPS
12/19/2012 1:56 PM
Never mind the teasing. An inverter converts a generic DC input, such as from an alternator in a motor vehicle, to an AC voltage (typically set to some standard line voltage and frequency). A UPS has a dedicated battery attached to an inverter, and typically also includes a battery charger powered by the primary AC line. Most UPS units also do line conditioning and regulation by routing power directly from the battery charging circuit to the inverter during normal operation from the primary line, thereby simplifying the switchover circuitry.
Re: Inverter vs UPS
06/28/2013 11:44 PM
Thank you so much !!
Re: Inverter vs UPS
12/20/2012 5:20 AM
Inverter is only a device doing the opposite function of a rectifier but UPS is a storage device consisting a rectifier,battery and inverter.
pnaban
Good Answers: 244
Re: Inverter vs UPS
12/21/2012 11:06 AM
The function of inverter is to convert DC to AC and hence the inverter is used when the DC system is required to be converted to AC system. In the UPS, the AC is first converted to DC and then the DC is again converted back to AC. The three major components of the UPS system are battery charger, battery and inverter. Therefore, when inverter is used in context of UPS, it is one of the major components of UPS system.
However, Inverter can also be used as standalone equipment for converting DC to AC or integral part of other equipment such VFD.
- MS
Register to Reply 9 comments
Joshi (1); JPool (1); JRaef (1); lyn (1); MNIce (1); msamad (1); pnaban (1); PWSlack (1); Sibin (1)
