Previous in Forum: Pressure / Strength Testing   Next in Forum: What is the Maximum Accepted Pump Runout
15 comments
Pump Flow Rate
12/19/2012 4:17 AM
I have model:
model: 450LS by silverson homonizer pump. i would like to know the flow rate, Pressure but the tag plate of the pump gives the clue of mach no: 450LSM2080.
Please assist .
Pathfinder Tags: 450LS flow rate pump
Re: Pump flowwrate
12/19/2012 4:44 AM
Give these people a ring, and talk to them:
http://www.silverson.com/
Good Answers: 34
Re: Pump flowwrate
12/19/2012 5:01 AM
I tried www.silverson.com/ but they do not have any mention of this pump. How old is this pump? May be they did not make it but outsourced it. You already have the flow rate = 450 litres per minute. You can always measure the pressure. 2080 may be the year of manufacture of the pump.
Re: Pump flowwrate
12/19/2012 5:36 AM
"2080 may be the year of manufacture of the pump..." - only if someone's found the keys to the KrisDel™ Time Machine . I though they went down the plug-hole.
Good Answers: 34
Re: Pump flowwrate
12/19/2012 5:59 AM
...they went down the plug-hole.
What a pity! How sad.
Re: Pump flowwrate
12/19/2012 6:01 AM
Listen to the chanting masses as the nerk with the loudhailer whips them into a frenzy:
"What do we want?"
"Time travel!"
"When do we want it?"
"It's irrelevant!"
Re: Pump flowwrate
12/19/2012 8:30 PM
I think more than 10 years. that is why i am here to seek expertise.
Re: Pump flowwrate
12/22/2012 6:55 AM
Could be August 2000
Re: Pump Flow Rate
12/19/2012 9:16 AM
It's not a pump. It's a mixer.
Good Answers: 34
Re: Pump Flow Rate
12/19/2012 9:25 AM
Thanks, lyn. I thought as much. How strange that the OP does not know what he has & what he wants?
Re: Pump Flow Rate
12/19/2012 10:06 AM
"How strange that the OP does not know what he has & what he wants"
Actually that's all too normal for OP's here.
Re: Pump Flow Rate
12/19/2012 11:26 AM
So. This is a mixer and not a pump (see #6↑).
So the flowrate is whatever the [something else] is passing through it.
Re: Pump Flow Rate
12/22/2012 7:07 AM
This is a Mixer Homogeniser. Contact them and ask them what ever info you need. They might (or should be able ) to give you a copy of the specifications for this mixer.
http://www.silverson.co.uk/en/products/homogenisers.html
Good Answers: 34
Re: Pump Flow Rate
12/22/2012 7:33 AM
You have been looking for this info, for 10 years! You are great! Now, download all details from: http://www.silverson.co.uk/en/in-line-mixer-technical-information.html
Re: Pump Flow Rate
12/28/2012 4:36 PM
A very easy task: Obtain the performance curves for that exact model, size and speed pump from the manufacturer. Read the suction and discharge pressures with the pump operating. Enter the difference of the two pressures onto the curve shown for the appropriate speed and that curve will tell you the volume pumping in gallons/liters per minute. The BHP will be shown for water. For fluids of a specific gravity different than water, the volume will remand the same but the BHP will change accordingly. Your pump supplier can help you with all this.
Lou bindner
Re: Pump Flow Rate
12/28/2012 6:40 PM
That would've been a good answer - and "a very easy task" - if the device in question was a pump.
If you'd taken the time to read the previous posts, you'd've discovered that it is a mixer homogenizer. Makes stuff like Brylcreem and mayonnaise.
5/10 must try harder.
Register to Reply 15 comments
Anonymous Poster (1); JohnDG (2); Joshi (4); LAA_Lucke (2); Lou Bindner (1); lyn (2); PWSlack (2); westdeap12 (1)
