Previous in Forum: Pump Flow Rate   Next in Forum: Hoisting Mechanism in Brake Load Concept
What is the Maximum Accepted Pump Runout
12/19/2012 7:01 AM
good day
1what is the maximum accepted single stage Pump Runot?
2what is the maximum accepted single stage Pump Runot (impller side)?
3it depends p Runouton what?
4 is there chart help me on that or paper or site? (5 can you provide?)
best regards
Re: what is the Maximum Accepted Pump Runout
12/19/2012 7:25 AM
It is determined by the maximum tolerable runout at the maximum delivery pressure on the seals surrounding the impeller shaft, subject to the impeller not colliding with the inside of the pump volute as it spins and the seals surviving the experience without the pump leaking. It will vary from pump size to pump size and from manufacturer to manufacturer.
For more information, talk to the pump manufacturers' technical representatives.
If in doubt, renew the pump(s).
Re: What is the Maximum Accepted Pump Runout
12/19/2012 8:25 AM
Where do they come from?
pump runout definition
12/19/2012 11:56 AM
Check the corresponding pump curve to your model and make of pump
12/19/2012 11:28 PM
Hi
Do you mean eccentricity or are you talking about volume when you say pump runout
12/20/2012 1:58 AM
i mean
Runout is the straightness of the rotor
we fix the rotor horizantally and fix dial gauge on it then rotate the rotor and we check the straightness (Runout) of the rotor.
i lost the OEM manual because of that i was asking if there is api standard or any chart or fourmula or anything that will show what is the maximum allowable runout
12/20/2012 7:42 AM
This depends on the pump make and model.
There is no one value for this.
Contact the pump maker!
12/20/2012 3:16 PM
The allowable runout on the impella will depened on the RPM of the impella as well what Rev,s is it doing
Register to Reply 7 comments
lyn (2); Master of Naught (2); midofnowhere (1); phoenix911 (1); PWSlack (1)
