Previous in Forum: Translucent Fiberglass Sheets   Next in Forum: Merry Christmas and a Happy New Year
13 comments
How to Identify the Heat Detector and Smoke Detector?
12/21/2012 7:53 AM
If only see the case, how to identify it?
Re: How to identify the Heat Detector and Smoke Detector?
12/21/2012 7:56 AM
Read the writing on the case.
12/21/2012 8:01 AM
Blow some smoke on it. If it alarms, it's a smoke detector.
If not, it's a heat detector.
Good Answers: 34
12/21/2012 8:12 AM
Alternately, bring some heat source (without smoke) close to it, if the alarms goes, it is a heat detector.
If not, it is a smoke detector. (My apologies, lyn.)
Re: How to Identify the Heat Detector and Smoke Detector?
12/21/2012 8:27 AM
Should be labeled somewhere on case. Should throw CO detectors in there too, they all look alike
Good Answers: 125
12/21/2012 9:21 AM
Like the others have said, remove the device from the socket by rotating it counterclockwise.
This will put the control panel in a trouble state but will do no harm otherwise.
If you can't tell what it is, post the model number here and we will identify it.
Smoke will normally only activate a photoelectric type detector, not an ionization type (contrary to popular belief, and what you might read on the internet).
Ionization detectors respond to the ionized particles of combustion which can occur in the incipient stages, even before you can smell a fire.
Without proper equipment, test this type of detector by blowing ash from a lit cigarette toward the device.
Anonymous Poster #2
12/21/2012 10:42 AM
If it's the one waaaay up high that you can't reach and it goes off every single damn time you cook anything in the kitchen, then it's a smoke detector.
Good Answers: 299
12/21/2012 3:22 PM
Boy that brings back memories...
With Ex-Mrs. Doorman #2, when the smoke alarm started singing supper was almost ready.
Her motto was "Timer? I don' need no steenkin timer!"
12/21/2012 3:36 PM
Our little house in Minn. is like that. You have to disable it to cook.
Boy, glad I'm not there now! Snow everywhere and 15°F
Good Answers: 299
12/21/2012 4:00 PM
With Ex-Mrs. Doorman #2, the issue was neither the sensitivy of the smokies nor the size of the kitchen. There was a belief that maximum flame cooked stuff faster, thus better. The food passed right thru cooked while on the way to being burnt (her customary and standard technique), thus tripping the smokie.
15° F? Whew, it's warm over there, eh?
Gasoline here was down to $3.00 per US gallon for a while. Jumped up about a dime in the last few days.
12/22/2012 12:42 AM
Smoke detectors have louvers for smoke to enter and activate the sensor/detector. Remember there are different kinds of heat(fixed temperature/rate of rise) and smoke(ionisation/photo electric) detectors
pnaban
Good Answers: 179
12/22/2012 9:18 AM
Ahhhh jeezzzz, turn over the box and read the back and side panels? LOL
12/22/2012 6:48 PM
Ever known a cook that uses one of those rather than an egg timer?
Good Answers: 25
01/09/2013 4:24 AM
Well done!!
Register to Reply 13 comments
Anonymous Poster (2); CaptMoosie (1); Doorman (2); Joshi (1); JPool (1); kudukdweller9 (1); lyn (2); pnaban (1); PWSlack (1); WJMFIRE (1)
