Previous in Forum: Basic Generator Setup Question   Next in Forum: LOHER Motor and Bearing Axial Float
Loncin LC 5000DDR
12/22/2012 4:49 PM
Cannot get 240 volt output. 110volt will not run a 1000w Kango Breaker.
Whats wrong?
All suggestions welcome.
Re: Loncin LC 5000DDR
12/22/2012 5:05 PM
12/22/2012 6:49 PM
There is a fault. What it is cannot be seen from here.
12/23/2012 2:21 AM
obviously you cannot operate the kango rated for 240v with availble 110 v
Good Answers: 34
12/23/2012 6:49 AM
What monstor is this Loncin LC 5000DDR ? Is it a genset ?
Good Answers: 102
12/25/2012 5:08 AM
First verify that this is a Kango that wants 240V and not 110V. (no location given so can't guess that one) I'm assuming it's 240V you need, trying the 110V output was a nice bit of jungle engineering logic if it is.
That genset should be able to do a 4000W load and have 240V output. (I googled that so it must be true)
So at risk of stating the obvious, there's something wrong in the 240V part of it.
Have you checked all fuses and/or circuit breakers yet? Do you have a manual? What tools do you have (other than the kango hammer)
Could be anything from a gecko in the alternator to a wallabied regulator.
Joshi (1); lyn (1); PWSlack (1); ramasmy (1); Wal (1)
