Previous in Forum: Loncin LC 5000DDR   Next in Forum: Wind Span and Weight Span Etc. Calculation
LOHER Motor and Bearing Axial Float
12/23/2012 1:33 AM
Subjected Motor was just overhauled and new bearing is installed, but axial Play was checked and found 0.40mm, any idea about recommended axial float!
Motor type: DNLW-250MB-02M
Bearing type: 6314M/C3
64 kW
480 V
Speed: 6566 (VSD)
93 A
110 Hz
Thanks in advance
Fahad
Re: LOHER Motor and bearing Axial Float
12/23/2012 2:09 AM
This Motor is installed in vertically position, drive a flowserve pump.
12/23/2012 4:42 AM
It depends of the temperatur rise of the shaft. Expand coefficient for steel is 12*10 - 6.
So if temp rise is 82 °K you will need 0.000012*82=0.000984m I would then give it 2mm.
Good Answers: 183
12/23/2012 12:05 PM
The coefficient is in M/M or inch/inch so that the elongation for 82 K will be 984E-6 m/m. The 0.4 mm will be reached for a shaft 406 mm and the 2mm for 2000mm.
12/23/2012 12:34 PM
Vertical Pump motors ( and all others ) should always have a fixed bearing in the drive side,and the axial float in the non drive side. So it is free of risk to give a little bit too much axial play, but very expensive with insufficient.
If the bearings are changed because of bearing failure , then cut the old bearings and take a look in the tracks. it might give the answer .
12/23/2012 9:08 AM
Who overhauled it and what do they say about this value?
What does the motor manufacturer recommend?
Anonymous Poster (1); Fahad (1); lyn (1); moan8452 (1); nick name (1)
