Previous in Forum: Centrifugal Blowers   Next in Forum: Flange
Can Support Directly Weld to Pressure Piping?
12/26/2012 1:36 AM
Hi,
I have questions on issue of "directly weld to the piping". I hope anyone could share their knowledge with me. Few questions regarding to the subject;
In ASME B31.3; it is stated that;
"Integral attachments include plugs, ears, shoes, plates, trunnions, stanchions, structural shapes, and angle clips, cast on or welded to the piping. The material for integral attachments attached by welding shall be of good weldable quality. Preheating, welding, and heat treatment requirements shall be in accordance with Chapter V. Consideration shall be given to the localized stresses induced in the piping component by welding the integral attachment, as well as differential thermal displacement strains between the attachment and the component to which it is attached."
From what I understand (pls correct me if I am wrong), support can be directly welded to pipe as long as it has good weldability. Also preheating, welding, heat treatment as per Chapter V. And localized stress and thermal displacement have been considered.
My question;
1) How to consider localized stress and thermal displacement? Anyone has done it before? Could you pls share step by step? I am really clueless.
Meanwhile in ASME B31.4, it is stated that;
"If pipe is designed to operate above 20% SMYS, all attachments welded to the pipe shall be made to a separate cylindrical member that completely encircles the pipe and this encircling member shall be welded to the pipe, by continuous circumferential welds."
From what I understand (pls correct me if I am wrong), if pipe designed to operate above 20% SMYS, the pipe must have encircles member that is circumferential welded to pipe, then we can attach the support to the encircle member.
My questions;
2) Is that mean if pipe is designed to operate below 20%SMYS, we can actually directly weld our support to the pipe?
3) How could I define whether my pipe is designed to operate below or above 20% SMYS?
Thank you for your time spent.
Pathfinder Tags: direct weld piping support
Good Answers: 34
Re: Can support directly weld to pressure piping?
12/26/2012 7:47 AM
Every job is executed as per the design drawing provided by the client. Are you designing this piping? If yes, then you should spend some more time as an apprentice & hone your skills. In the meantime follow the clients instructions.
12/26/2012 10:59 AM
I would normally avoid welding to a pressure pipe because of possible differential movement such as vibration, expansion and contraction. The only time I would weld directly is within a pressure vessel as between bulkheads in a submarine and then I would use the encircling member as reinforcing for the pipe.
Mr.Ron from South Ms.
Good Answers: 61
Re: Can Support Directly Weld to Pressure Piping?
12/26/2012 4:03 PM
Yelettew,
The answer to your basic question "Can I weld a shoe direct to pipe?" is yes.
Go here: http://www.pipingtech.com/products/ptpcat/pipeshoes/withfw/index.html
you will see many examples.
Do it once and do it right
Good Answers: 102
12/26/2012 11:17 PM
SMYS, Specified Minimum Yield Strength.. you can look that up for the pipe you are proposing to use.
Whether or not you exceed 20% of that value will depend on what you are supplying it with....pretty basic starting point design info.
How to consider localised stress and thermal displacement? Localised stresses are things like the weight of attachments, vibration of attachments, weight and action of the pipe itself...thermal displacement is the pipe changing length with varying temperatures and so on......sounds like you need someone there to guide you.
Good Answers: 38
12/27/2012 12:13 PM
Thank you for your well worded and easily understood question.
For this forum, it is certainly a rare treat to have, in English, a properly posed question.
First, it is important to note that integral welded attachments should be discouraged in pipe support design. They cause design and installaton problems that can usually be avoided through use of other support types on the system.
Secondly, in my opinion, the only types of welded attachment that the p[iping system designer may be "forced" into using are welded lugs (usually on a vertical riser support) or trunions on a elbow, just beneath a riser.
All other circumstances can be "designed away" through the use of competent piping designers and good piping stress analysis software ( eg CAESAR-II).
There are ASME methods available to evaluate the localized stress in riser lugs, which are loaded mostly in simple shear. Make sure that the ASME materials selected for these lugs are the same as those of the piping.
Similarly, there are established methods available to evaluate the local stresses on trunions.
I cannot answer your 20% SMYS question
Joshi (1); MJCronin (1); PennPiper (1); ronseto (1); Wal (1)
