Previous in Forum: Soldering Piezoelectric Igniter   Next in Forum: Why Autotransformers Always Starts at Zero Position ?
10 comments
Megger Value
01/02/2013 7:52 AM
Happy New Year Everyone,
After megger test in 415V LV Switchgear Bus Bar, Reading comes at 300 Megaohm for Y-B & B-R Phase, however it is only 70 MegaOhm for R-Y Phase. I checked all the bolts tightness and surface of Bussbar for any external materials and spacing, it is all ok. can you suggest me what will be the problem and how to rectify it to get nearby reading in all three phases.
Thanks.
Re: Megger Value
01/02/2013 9:07 AM
Remove the spider's web hanging between the R and the Y busbars.
Re: Megger Value
01/05/2013 7:31 AM
It is new installation hence no spider web sorry...
Re: Megger Value
01/02/2013 9:13 AM
"can you suggest me what will be the problem": Imbalance in the system
"and how to rectify it to get nearby reading in all three phases." Call an electrician out to fix it.
Good Answers: 131
Re: Megger Value
01/02/2013 11:02 AM
70 megohms on 415V electrical insulation is acceptable. There are always some variations in resistance between phases - you will NEVER get them exactly the same. All it takes is a little dust on one of the insulators, a little moisture in an area that gets less ventilation, or something minor like that to give you the difference.
What is your insulation resistance to ground? That is also important.
Re: Megger Value
01/02/2013 4:08 PM
we'll never know but....if he warms the general area and takes his readings again they'll probably change...due to moisture
Re: Megger Value
01/05/2013 7:33 AM
I Used Space Heater for a day....Reading did change marginally(now 82 mega ohm) but no where near 300 or so.....Damn!
Good Answers: 15
Re: Megger Value
01/03/2013 4:41 AM
With everything disconnected you would expect almost infinity. I go with the looking for things like spiders and similar debris.
Checking things for tightness will not increase the insulation value.
While it is in bits I suggest a ductor test. Now on this test clean and tight joints really will make the difference. If might be this test will unearth something. You are looking for a really low value.
A flash test might clear the spiders but its a little harsh .....
Re: Megger Value
01/03/2013 1:08 PM
Is it Delta or Wye wiring?
Re: Megger Value
01/05/2013 7:27 AM
it is Wye
Re: Megger Value
02/20/2013 11:44 AM
I hope there is a control transformer for that bus bar system. If it is so, the primary of that transformer must have been fed from R and Y phases. It might be because of the insulation level of that particular MPCB which is feeding that trafo that the megger value between R and Y phase is comparitively low.
mscs
Anonymous Poster (3); Fredski (1); lyn (1); MSCS (1); Munster (1); PeterT (1); PWSlack (1); silverfox (1)
