I want to know which material is suitable for making a nozzle for a SA 516 pressure vessel.Can you please tell me is it safe to use same material for making the nozzle ??
It would be, if they made pipe out of it. (SA516 is plate.) You can use pipe of the same p-group as SA516. The tensile strength may be somewhat less, but this is accounted for in the nozzle/reinforcement calculations. If impact testing is required, such as for low-temperature service, some additional checking may be needed.
This is my first design and my aim is to design a suitable nozzle for the SA 516 Gr Pressure Vessel. It is a thin cylinder pressure vessel used for storing liquid chlorine in chemical industry. it is cylindrical type with ellipsoidal dish end.
So my Doubt was whether the same material can be used for making the nozzle.??
