Previous in Forum: Flare KOD.   Next in Forum: stg
I Have Problem in DX Package Air Conditioner
01/08/2013 8:43 AM
I pressurised system by nitrogen 350 Psi after 48 hour observations no leak found , But if we are charging refrigerant in the system there is conformed leak but leak can not found please friends advice me solutions .
Thanks
Zaka
Re: I Have Problem in DX Package Air Conditioner
01/08/2013 9:06 AM
If the refrigerant is gas at everyday temperatures and pressures, then a strong solution of washing up liquid detergent squirted onto any place where a leak is suspected will result in bubbles being formed.
01/08/2013 9:39 AM
what are you using to detect this confirmed leak? hopefully not simple "bubbles"
Good Answers: 104
01/08/2013 9:44 AM
"...no leak found" - was the complete system bubble checked while under pressure, or was the pressure just monitored?
"...conformed[sic] leak" - how do you know there's a leak? In any case, if there is a leak, it can often be found just by the presence of lubricating oil on the area of the leak.
Register to Reply 3 comments
bigg (1); Fredski (1); PWSlack (1)
