Previous in Forum: Replacement of a Clinker Satellite Cooler by a Grate Cooler in a Cement Kiln   Next in Forum: Large Plug With Non-Standard Thread
21 comments
Orifice Size
01/09/2013 12:32 PM
With a constant supply of compressed gas (nitrogen) at 3.0 bars,
What are the sizes of orifice (holes) needed to deliver 2, 5 and 12 grams/second?
Re: orifice size
01/09/2013 12:34 PM
Is this a homework question?
Re: orifice size
01/10/2013 10:24 AM
yes it is.
Thanks.
Re: orifice size
01/10/2013 10:39 AM
Do you understand that grams/second is not normally used to describe the flow rate of a gas?
And that the answer depends on many still unknown factors.
Good Answers: 137
Re: orifice size
01/10/2013 11:04 AM
I don't see much wrong with describing the flow rate of a gas in grams/second. It's easy enough to convert to normal or standard m3/h, or similar in other units.
Re: orifice size
01/10/2013 11:32 AM
I know it can be done. Question is, does the student?
Good Answers: 137
Re: orifice size
01/10/2013 11:58 AM
Dunno, maybe he'll come back and tell us
Re: orifice size
01/10/2013 5:33 PM
use these till you get the rate you desire
Good Answers: 73
Re: orifice size
01/09/2013 12:36 PM
It sure looks like it! The answer is on the graphs you should have.
Re: orifice size
01/09/2013 12:37 PM
download engineering power tools, this may help, but you may have to add some constance
Re: orifice size
01/09/2013 12:41 PM
Re: orifice size
01/09/2013 12:42 PM
Grams per second? It's a trick question.
Re: Orifice Size
01/09/2013 1:26 PM
Yes a trick question, and determining the orifice design tricky as well....good luck
Good Answers: 101
Re: Orifice Size
01/09/2013 3:35 PM
One would be small, the next would be slightly larger, and the third, would be a bit larger yet.
Not sure how to deliver grams/second of compressed nitrogen, not sure that's possible.
Perhaps you should consult your instructor, and ask about those units.
Good luck!
Good Answers: 137
Re: Orifice Size
01/10/2013 9:31 AM
You need to say
1) whether the supply pressure is gauge or absolute
2) downstream pressure
3) upstream temperature
4) is the orifice in the side of a vessel, in a pipe, or what?
Re: Orifice Size
01/10/2013 10:40 AM
The pressure gauge is absolute.
the down flow (pressure) into a container and as the container reaches set pressure
flow stops.
as gas form the container/storage is consumed/utilized at the set volumes (to atmosphere) via the orifice(s) the container/storage is continuously maintained via a pressure regulator form higher source.
the orifice discharges into a chamber (typically atmospheric press.)
Good Answers: 137
Re: Orifice Size
01/10/2013 11:01 AM
That doesn't quite hang together. You say "the down flow (pressure) into a container and as the container reaches set pressure flow stops". Badly worded but I know what you mean. But then you say the upstream pressure is maintained, so you're talking about a steady state condition, and you give specific flow rates. You don't give upstream temp so I'll assume 20°C.
As the downstream/upstream pressure ratio 1/3 is < critical ratio ~ 0.53, flow is sonic. I make dias
2 gm/s 2.43 mm
5 gm/s 3.84 mm
12 gm/s 5.95 mm
Re: Orifice Size
01/10/2013 1:14 PM
Doesn't happen often, but it looks like you got somebody to answer your homework question for you.
Re: Orifice Size
01/10/2013 5:53 PM
I'm still trying to figure out why we are measuring a gas by weight.
How much space does 12 grams of N2 occupy, at let's say 25°C?
Good Answers: 137
Re: Orifice Size
01/10/2013 6:16 PM
Molecular mass of N2 = 28. Molar volume at NTP (1 atm, 0°C) = 22.4 litre/gm.mol. So 12 gm at NTP occupy 12/28*22.4 litre. You didn't specify pressure, but at 1 atm and 25°C, volume = 12/28*22.4*(273 + 25)/273 = 10.48 litre.
Re: Orifice Size
01/10/2013 6:28 PM
I found this, Don't know why you would need to, but here it is :
Use equation n=PV/RT where n is number of moles and R is gas constant. Use R= .8314 L-Atm/mol-K. convert 3 ml to liters(3/1000) and 100C to Kelvin (100+273) and solve for moles.
Convert moles to grams. 1 mol of N2 equals 28 grams
http://wiki.answers.com/Q/Calculate_the_mass_grams_of_N2_gas_required_to_occupy_a_3.0_mL_container_at_100_C_and_0.914_atm_and_explain_how_you_did_it
The state of an amount of gas is determined by its pressure, volume, and temperature. The modern form of the equation is: PV = NkT, where P is the absolute pressure of the gas; V is the volume; N is the number of particles in the gas; k is Boltzmann's constant relating temperature and energy; and T is the absolute temperature.
http://www.chacha.com/question/what-volume-will-14-grams-of-nitrogen-gas-occupy-at-a-pressure-of-2-atm-and-temperature-of-27-c
http://en.wikipedia.org/wiki/Ideal_gas_law
Re: Orifice Size
01/10/2013 7:19 PM
Thanks guys.
It was sort of a rhetorical question for the OP.
Register to Reply 21 comments
Codemaster (5); Fredski (1); JPool (4); lyn (5); NotUrOrdinaryJoe (1); phoenix911 (1); RVZ717 (1); SolarEagle (1); wasp (2)
