Previous in Forum: To Measure Output Pressure   Next in Forum: Formula for Density Calculation Steam
Main Steam Flow Compensation Calculation
01/12/2013 1:14 AM
Dear friends, regarding the flow compensation i have seen in many threads. In our power plant for calculating main steam flow we are using the following equation,
{19*P(actual)}/{1.48+0.01*T(actual)-0.0452*P(actual)*42.44} . Help me to understand the formula.
And I know the general formula is,
SQRT Actual flow*(density at operating temp and press/density at designed temp and press).
How to co relate the above equation with below equation.
Kindly give me some ideas or suggestions, how to get the formula.?
Re: Main steam flow compensation calculation
01/12/2013 9:40 AM
Please give the source(s) of this infomation so that an assessment can be made.
Re: Main Steam Flow Compensation Calculation
01/12/2013 6:15 PM
Also, please tell us what units you are using.
P= inches of water, inches of mercury, psia, psig, bar?
T= Fahrenheit, Celsius, Kelvin, Rankin?
F= GPM, LPM, bathtubs per fortnight....?
I have often seen where someone has taken some unit of measure, multiplied/divided it by some constant or correction factor, and not explained the result. That is very frustrating, to say the least.
01/12/2013 11:44 PM
Pressure - MPA,
temperature - Degree celsius,
flow - CUM/Hr,
Good Answers: 54
01/13/2013 3:21 PM
So flow = P/(t-P)? That doesn't look dimensionally correct.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Register to Reply 4 comments
ffej (1); Kilowatt0 (1); pradeepdhoni (1); PWSlack (1)
