Previous in Forum: Start up Substation   Next in Forum: Cable Lug
132KV Disconnector Switch
01/18/2013 8:10 AM
Dear all
What is the difference between vertical and horizontal 132KV Disconnector switch & is it permissible to use one instead of the other
Regardes
Pathfinder Tags: 132KV Disconnector switch
Re: 132KV Disconnector switch
01/18/2013 9:14 AM
Do you mean aside from the obvious?
Re: 132KV Disconnector Switch
01/18/2013 11:08 PM
Basically the vertical and horizontal disconnector switch is purely the construction based variant, either it can be vertical / horizontal blade / knife type. the only thing you have to concentrate is , the continuous current rating, and fault level with standing capacity. Also is it mechanically suits the conductor, without reducing the area of contact.
Register to Reply 2 comments
