Previous in Forum: Flame Proof Electrical Motor   Next in Forum: Fridge Compressor Motor Runs Slow
Microswitch for Switching Mains Light
01/19/2013 11:21 AM
I want to use a 250V AC, 5A rated microswitch in a wall light switch. The device would turn a lamp on and off.
The load would vary from an 11Watt low energy bulb to a 150W halogen bulb.
Although the rating seems sufficient, is a microswitch suited for this purpose?
Are there any problems I should be aware of?
Many thanks.
Re: microswitch for switching mains light
01/19/2013 11:28 AM
Yes.
No.
You're welcome.
Re: Microswitch for Switching Mains Light
01/19/2013 12:07 PM
Why not a regular light switch? What sort of mechanical arrangement will you use for the microswitch?
01/19/2013 6:02 PM
Happy to use any push button switch which has a pre-travel (distance before contact is made) of over 1mm and a total travel before it latches of 3mm or so. The switch is designed just to be pressed lightly to operate. I just want a switch with a long mechanical life that can handle lamp loads and won't burn out or overheat (despite being appropriately rated). If you have any suggestions, they would be welcome
01/21/2013 3:32 AM
<...suggestions...>
Yep. Use a commercial product with the correct rating instead of home-brewing something. It saves one becoming unpopular with fire insurance companies.
Register to Reply 4 comments
lyn (1); mehram (1); PWSlack (1); Tornado (1)
