Previous in Forum: NTC in Variac Circuit   Next in Forum: Potential Transformer
DC Motor Drive Parameterise
01/20/2013 11:30 AM
Dear Friends,
I would like to know how to increase the mechanical load capacity 5 to 10% more of dc motor 22kw 380 V, model # DMP160-4M, 160426385, make; ABB, at present motor working only 80% of capacity.The motor has driven through DC drive ABB, model # DCS 500 Part # DCS502B0075-41-212000, in put power;380 V 3 phase, 60 HZ, the drive is working as a constant torque mode, please let me know the parameter setting for incease the mechanical load capacity by 5 to 10% more.
Kind regards
Re: DC motor drive parameterise
01/20/2013 11:45 AM
Did you not get the manual?
Or, are you just lonely?
DCS 500B / DCF 500B DCP 500B - ABB Download Center
Good Answers: 804
Re: DC Motor Drive Parameterise
01/20/2013 10:02 PM
I can't understand what you are asking for. The DC drive has a CAPACITY of 22kW according to you. That is the capacity of the drive. If it is too small for the motor, you have the wrong drive.
A MOTOR will only use the power that it needs to use to do the work you expect from it. You cannot "force" a motor to run at 100% capacity by doing something in the drive. If the motor is running at 80%capacity, that is because the work load on the motor only requires 80% of its capacity. You should be happy with that. I don't see what yhe problem is here.
01/21/2013 9:36 AM
Electrical load is torque multiplied by angular velocity divided by efficiency. So the only way to increase the load on the motor is to change something mechanical on the thing the motor is driving.
On rising above 100% load, the drive needs to disconnect the motor so as to protect it. Altering the mechanical arrangements has no bearing on the parameter settings in the drive, which should remain "as commissioned" so as to protect the motor and the supply cables to a certain extent, though the supply fuses are the final arbiter. In any event, the electrical set-up needs to be in accordance with the local electrical code; BS7671 prevails in the UK.
So the question as written is meaningless.
Register to Reply 3 comments
JRaef (1); lyn (1); PWSlack (1)
