Previous in Forum: X, Y, Z Tolerences   Next in Forum: Gross Combination Weight Rating
10 comments
Tractor Steering Repair
01/22/2013 3:12 AM
Hello all,
I have a Massey Ferguson Tractor Model 165 which has a big play when steering both left and right. What can i do to fix this problem? Thanks in advance.
Re: Tractor Steering repair
01/22/2013 3:25 AM
Replace the worn-out components.
01/23/2013 5:36 PM
Seems obvious, wonder why he(she) had to ask. GA -- JHF
Good Answers: 266
Re: Tractor Steering Repair
01/22/2013 7:44 AM
Powered steering?
Good Answers: 69
01/22/2013 9:09 AM
Replace all rod ends, replace the sliding coupling bell at the shaft, buy the repair kit of "the bottle", it is the gearbox that transmits motion from the steering shaft to the pitman arm.
Before you dismount the bottle, turn fully left or right, then count the exact turns to the position where you will open it and leave it right there when you're done with the kit, reverse the dismount procedure and voila ! now you really HAVE to call a mechanic.
It ain't no rocket science, you don't really need to know how, just dare and the mechanism himself is going to tell you how he works.
01/22/2013 9:47 AM
You might need one of these kits...
Description
Complete Steering Box Repair Kit.
Contains:
Steering Shaft,
Rocker Shaft,
Rocker Shaft Bushes x 2,
Rocker shaft Seal,
Rocker Shaft Dust Seal ,
Upper and Lower Bearings ,
Steering Column Gasket
Side plate Gasket.
This Kit contains all moving parts in the Steering Box (all shown in Photo)
Manufacturer Part No.(s)
Massey Ferguson:
1853121M1
01/23/2013 5:38 PM
Add tie rod and/or drag link ends. -- JHF
05/30/2013 2:50 AM
Thanks i fixed the tractor.
01/23/2013 12:04 AM
Hi
With the massey ferguson steering there is a little shuttle valve on top of the ram infront of the radiator, the linkage to this can get quite worn and will require replacing . Also the pivot arm that goes down through the front casting could need the bushes replacing, there is a tappered pin with a lock nut on it that links the steering to this arm and may need repairing or adjusting. It must have a small amount of movement to activate the ram that is why you need to make sure the ram linkages are ok first. If you pop the grill out you will see where the problem is when some one turns the steering wheel
01/28/2013 11:16 PM
I know a few tractors have the hydraulic pump running from the PTO. Also could be a clgged filter or kinked line in the siphon. Any leakage at all that you noticed?
02/18/2013 1:27 AM
No leakage!
Register to Reply 10 comments
Circuit Breaker (2); johnmathew (1); Master of Naught (1); Okindo (2); ozzb (1); PWSlack (1); SolarEagle (1); Yahlasit (1)
