Previous in Forum: Difference Between Trial Assembly and Pre-Assembly?   Next in Forum: Selecting a Mechanical Seal and Seal Flush Plans per API 682
Gear Box Output Torque
01/24/2013 5:25 AM
Hi I want to know output torque of gear box. Following data's. Servo motor rated torque-5.6NM, rpm 3000 & gearbox ratio-6 Gear box nominal torque is 150 NM. Please tell me gearbox output torque?
Re: Gear box output torque
01/24/2013 5:44 AM
Is the gearbox output 6 times faster or slower than the motor? If slower, then output torque = 6 x input torque; if faster then output torque = input torque/6 (neglecting gearbox efficiency).
01/24/2013 6:37 AM
Thank u sir, Can you suggest ball screw max. size and pitch for same torque. Please.
01/24/2013 7:06 AM
Without seeing the installation, how does 150mm Ø, 10 turns per metre sound?
01/24/2013 7:50 AM
That'd be fun at 18,000 rpm .
01/24/2013 8:04 AM
JohnDG (2); naiduganga5 (1); PWSlack (2)
